B7800 w/cab fueling
/ B7800 w/cab fueling
It hard to beat $2.99, and no future battery cost either.
I paid $12.99 for the Kero World "D" battery one I got at True Value,
Home Depot also had one for $12.99, I did see one for $22.99 at Ace Hardware and I could not really see any difference among the three of them.
/ B7800 w/cab fueling #22
You can buy battery operated siphon pumps through Amazon.com for around 8 to 10 bucks. The are through a company outside of Amazon, but what the heck. I had a B7800 and had the same issues. I finally put a longer hose on the diesel can and lived with it - too good of a tractor to worry about a minor inconvenience. I finally traded up to an L5740 when I started feeding haylage to my livestock and got tired of the REALLY light front end when carrying a haylage bale on the 3 point spear. Would have liked to have kept the B7800 for smaller chores.
Amazon.com: Battery Syphon Pump: Kitchen & Dining
or
http://www.amazon.com/World-Mktg-DH-20-Battery-Siphon/dp/B000HE9YEM/ref=pd_sbs_k_5
/ B7800 w/cab fueling #23
Here is a picture of the $2.99 hand powered fuel filler from TSC. I've used these for years and they work great. I set the 5 gallon container on the hood and get it to start pumping, wait till it's filled or container empty then get the container off the hood. I do like the idea of the battery operated one and may get one of them but for 7 times the money I have to worry about keeping a working battery in it. Also when my wife loses this one I'm only out $2.99 instead of $20. For some reason she has to move anything I have setting around.:)
I've used those for years & they work great. They last a long time. And they're cheap. Now I have something that works even better for me. I have a 55 gal. drum which originally had motor oil in it. I made a 4-wheel dolly for it. I bought a rotary hand pump for it. It's on a concrete floor & I roll it up next to the tractor, put the nozzle in & crank away. I have it filled with home heating oil when the oil guy comes. It doesn't get much handier than that. The reasons I went with the hand crank pump over the electric pump is it's cheaper & I don't have to worry about getting fuel when the electric is off.
I'm not getting any younger & those 5 gal. cans aren't getting any lighter. And I don't have to fight with those "environmentally friendly" cans.
/ B7800 w/cab fueling #24
The reasons I went with the hand crank pump over the electric pump is it's cheaper .
I have the oil guy come fill the 55 gallon drum with 55 gallon of off road fuel.
I always get 55 gallon.
That's why I went with a 12 volt electric pump powered from a battery charger plugged into a 110 volt outlet .
In the event of a power outage I can always connect the pump to the battery of one of my 4 tractors or one of the 3 pickups.
/ B7800 w/cab fueling #25
[/color]
ARE ALL 3 PICKUPS THE SAME BRAND/SIZE/MODEL?:) You didn't show the pictures of your setup just because I said you would, didn't you? Come on LB, show em, some may not have seen them.
2016 Freightliner Cascadia (A64911)
2016 Freightliner...
ACS PORTABLE AIR COMPRESSOR (A64276)
ACS PORTABLE AIR...
2017 Mack Semi (A64047)
2017 Mack Semi...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
PT Water Tank Trailer (A64912)
PT Water Tank...
More info coming soon. (A64557)
More info coming...
