May Be Rethinking My Needs, Little Help, Please
/ May Be Rethinking My Needs, Little Help, Please #1
robertwhite
I am in a bit of a quandry(sp)
I have 15 acres that is pretty much flat. I was seriously thinking about getting an L series Kubota for overall chores. BUT........ The more I think about it, the more I think that I would be making a bad choice.
The acreage is around 10-11 lawn and 4-5 field. The previous owner used an old MF with a 5ft finish and had a few cows in the field.
I have been giving a lot of thought to the fact that even on an L series, the FEL is not all that large and if it happened to have a backhoe, there really is no digging depth or reach on a CUT, so the thought was always to get a used dedicated loader/backhoe (Case, Ford, whatever) to go with the tractor.
The more that I think about it, the more it is starting to make more sense to get a ZT mower (Dixie Chopper, preferably X series & at least 60" deck) and then get the used loader/hoe for all other chores.
Dixie Chopper claims to cut 8 acres an hour with the 72" and even if I got the 60", it would still only take a few hours. I would be getting cows in the field so that would maybe need a cut 1 or 2 times a year. (and probably could raise the deck on the ZT enough to do that). Fall leave mulching is also an easy do for the ZT, the SCUT not so much.
Is a CUT really the "be all, end all" of small farm use or is my second line of thought making any sense? I see lots of new (2yrs old, never sold) Dixies on tractorhouse, so I know they can be had in the $6-9K range, which is easily less than half of a new L series. Then pick up the loader/hoe for $6-8K and be done with it.
Any input of any kind would be great. If my idea is dumb, tell me so (I can handle it :p)
/ May Be Rethinking My Needs, Little Help, Please #2
I have been giving a lot of thought to the fact that even on an L series, the FEL is not all that large and if it happened to have a backhoe, there really is no digging depth or reach on a SCUT, so the thought was always to get a used dedicated loader/backhoe (Case, Ford, whatever) to go with the tractor.
Is a SCUT really the "be all, end all" of small farm use or is my second line of thought making any sense? I see lots of new (2yrs old, never sold) Dixies on tractorhouse, so I know they can be had in the $6-9K range, which is easily less than half of a new L series. Then pick up the loader/hoe for $6-8K and be done with it.
I see where you are coming from. We have 20 acres. Seven acres in pasture nine acres in yard. Four in woods. Flat as a pancake. I mow with a CUT and six foot RFM. Takes me about seven hours to mow my yard. Every single weekend. A ZTR would probably cut this time down to less than half. But I need the loader, brush hog, and post hole digger. I can't afford both the CUT with all the goodies and also a ZTR so I went the CUT route. I don't mind mowing the yard. But seven hours every weekend mowing is for sure a serious consideration. It's an important choice. For me it is the best comprimise.
/ May Be Rethinking My Needs, Little Help, Please #3
Just thinking,
The field may be a little rough for the ZT, after the Cows make their divots from walking around a rained soaked field or a Freeze/Thaw field in the winter will make for a rough time come summer. Not to mention the "Piles" that will start to appear after a few months.
Just thinking,
I thought the same thing too. The other thing I came up with is maybe pulling a used gang reel with either my Kawi Mule or my pick 'em up truck. Still in the thinking stage. :D
Like whistlepig said, I like mowing, but don't want to spend all day once a week doing it.
/ May Be Rethinking My Needs, Little Help, Please #5
Ok, I'm a little confused.:confused: You mention an L series Kubota and then you mention a SCUT. These are not the same size tractors. An L series tractor will take care of your place easily IMO. But a B series or a BX series would be a whole different set of conditions.
One of the problems with having a full size TLB for your only tractor is that you give up the ability to use any 3pt implements that you could otherwise use to make life easier.
/ May Be Rethinking My Needs, Little Help, Please #6
Take 5-6 acres of your lawn area and convert it into a wildflower patch. It will be prettier and you will spend less time mowing. Get some honey bees after you have a good stand of wildflowers. Put some bird nest boxes up in the wildflower patch.
I keep on recommending these lawn mowing 'solutions', please don't be offended. :)
Dave.
I know, I screwed that up. I actually meant a CUT, which is an L series, no?
A B or BX would definitely be too small. Figured that out a while back in another discussion.
/ May Be Rethinking My Needs, Little Help, Please #8
Dave.
One has to really love a large yard to put up with the hassle, expense, and time spent. Not for everyone.
/ May Be Rethinking My Needs, Little Help, Please #9
Yes, an L series tractor is a CUT. One of these would suit you well I think. I have a Case 580E TLB. While it is great to have a full size TLB, it is in no way a utility tractor. Keep in mind ALL the things that you MIGHT want to, or need to do.
See that's just it. Yeah I might need a post hole digger once or twice, but I could rent one.
I could use the TLB for heavy lifting, digging much faster and deeper, moving around whatever needs to be moved, grading, etc. I see 580E and the like for cheap money all the time. Doesn't have to be pretty, just work.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
IRanch IRMC High End Massage Chair (A60463)
IRanch IRMC High...
2017 Ford Fusion Hybrid Sedan (A61569)
2017 Ford Fusion...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
2016 Yanmar Vio45 (A60462)
2016 Yanmar Vio45...
LMC Ag 25 Gallon Sprayer (A60463)
LMC Ag 25 Gallon...
