Grapple Log Grapple.... 3Pt.
/ Log Grapple.... 3Pt. #2
/ Log Grapple.... 3Pt. #3
Have checked the "search" but found nothing on this piece of equip.
Welcome aboard, KOBIE.
I have seen the Wallenstein log grapple first hand at a dealer in Iowa. I
don't know anyone on TBN who has owned or used this one. In my
research, I have come across numerous grapples like this by Valby,
Addington, Brave, Branch, and BeaverSqueezer.
I was going to make one, if it ever got off my 'B' list of projects.
If you buy one, please post pix and your user experience.
This one's an Addington.
/ Log Grapple.... 3Pt. #4
Looks like it would put the load well above the centerline of the rear axle, so it could make for a light front end.
/ Log Grapple.... 3Pt. #5
I have skidded logs for many years with with skidding tongs chained to my drawbar. My method is cheap. A medium size skidding tong costs about $50. Plus skidding tongs allow you to lift the butt of the log closer to the center of gravity of the rear axel so your front end is less prone to get light. Skidding tongs will allow you to dedicate more actual lifting performance. The grapple due to its length will compromise your actual lifting capacity. Skidding tongs,however,are a bit slower than 3pt hydralic log grapple. Ya have to get off the tractor to set the dogs into the trunk before lifting.
A hydralic grapple might be worth the money if you were skidding a massive quantity of logs on any given day. If you are just moving a few logs a day. Not worth the money or degrade in lifting capacity.
/ Log Grapple.... 3Pt. #6
I've been using this home made unit for many years. It's not hi teck but it only cost about $10 to build.
/ Log Grapple.... 3Pt. #7
I put this together. It works well and with the winch frame being the fulcrum for the toplink I am able to touch the ground and pick the tongs or whatever I hang on the hook quite high. I only pick it as high as needed for stability.
I can also take the arm off and just use the standard toplink. It has a couple of hooks on it for chains and also a standard reciever for towing.
Posted this sometime back, just thought it might be an idea if you haven't seen it. Of course the winch is an opt, I had one so incorporated it.
/ Log Grapple.... 3Pt. #8
Looks like it would work great with some weight added to the front of the tractor. My uncle has used a pole boom with logging tongs for as long as I can remember.
/ Log Grapple.... 3Pt. #9
.....I have come across numerous grapples like this by Valby,
Umm.....There are so too many jokes to be made. I just can't choose between them all.
/ Log Grapple.... 3Pt. #10
I am sure the choice of product name was quite intentional.....and
unforgettable.
This one has a power rotate function.
/ Log Grapple.... 3Pt. #12
That's a sort of in between product. If you got the tongs on the balance point/middle, you could put a log on a low trailer perhaps. Not as rugged as a regular skidding set up. There is no side to side rotate either.
What would you try to accomplish with it that something much cheaper like ToadHill's homemade rig won't do, for example?
Dave.
