MT372 STARTER
/ MT372 STARTER #1
bigdan120
Hey Guys can you help me? I need to replace my starter and I read somewhere you can use a starter from a car or van and just change the nose. Does anyone know which make and model of car I need to get it from?
Thanks Dan
/ MT372 STARTER #2
To my knowledge, you aren't going to find an automotive starter to cross over to the Mitsubishi's. I know that the Ford Courier alternator crosses over to some of the mitsubishi tractors, used this one myself but I've not heard of an automotive starter cross over. You may want to post this in the Mitsubishi forum and see if any of the gurus there can give you any further insight on that but I have owned a number of larger model Mitsubishi's and follow the Mitsubishi forums pretty closely and don't recall anyone ever having any luck doing this. Give the Mitsubishi forum a shot and see if anyone has had luck doing this. The starters can usually be rebuilt, not always cheap though and I assume maybe you've received a quote and are trying to find a cheaper route.
/ MT372 STARTER #3
can you supply the real part number for the starter or possibly post a picture of the starter. the number should start the letter M followed by a number from 0 to 9 followed by another letter normally a T then followed by 5 more numbers. i will also try looking up by application when i get back to my shop wednesday.
thanks
mitch becton
also by the way with the proper part numbers you can find a lot of light truck and some auto applications that do carry the same starters and alternators as farm and industrial applications
/ MT372 STARTER
Thanks Guys... I seen a picture of a dodge Colt starter looks close to the right one. The tooth count is off though. I tore mine apart about 4 times cleaning it and trying it and after all that I found the starter gear drive was sticking bad. I cleaned it and then it would not catch so I found a replacement part for 15.00.That starter number was m4t14674 is what I found. They want anywhere from 300.00 to 500.00 for this starter ...LOL I will pull it down the road with rope by hand before I would pay that...LOL
/ MT372 STARTER #7
I thought you might be close by I have a starter shop I use about 30 mi. from me and he has always repaired anything I would bring him including Mitsubishi.good work and reasonable prices.
/ MT372 STARTER #8
glad you fixed your unit by some chance it does not work in the future for right now i can supply your starter number m4t14674 which by my books shows fitting a mitsubishi tractor. you cost would be $220.00 exchange it would be a reman unit. just email me if you need this .
thanks
mitch becton
/ MT372 STARTER
thanks
mitch becton
Thank You everyone for your help! I am going to see how long it lasts me ...
/ MT372 STARTER
Not sure if it is the same but I did find it again.../ MT372 same motor
For my S-370-D Beaver. I Found the answer to my slow, hard starting tractor on "Tractorbynet" From a member...DADZILLA...Get a starter for a Dodge Colt 1978 to 1980, 2.6 liter engine, automatic transmission.( bought one at auto zone for $91.00 for a re manufactured starter)
HOWEVER... You must take the the bell housing off of the OLD starter and put it on the new starter. IT WORKED GREAT FOR ME...
I had left the tractor sit for a month before I did this fix. Put on the new starter and ...I was shocked at the difference... About one engine turn before it took off.
I checked it out it has 8 teeth on the gear not 9.But if all you have to do is change the drive 15.00 dollars and nose then you will have almost a whole whooping 100.00 into a rebuilt starter that everyone wants 200 to 500 for....
Advanceauto
Worldwide Starter
Part No. 16514 59.99 10.00 core as of posting
/ MT372 STARTER #11
Hey guys,
I'm having problems with my starter too. Recently it stopped engaging sometimes, so I took it apart and gave it a good cleaning out and light lube which did help, but it still has the problem every few times I try to start it (Mitsubishi mt-372). To get it to engage when this happens, I "bump" the ignition until it catches and starts, which is usually only about two "bumps" but I'm sure is probably not very good for the gears.
I'd rather not dump $200 or more into a starter so I'm looking for "frugal" solutions first. My battery is a few yrs old but I don't notice a difference in cranking power from normal (I could be wrong) could a weak battery cause this Problem ? If I go with the Dodge Colt starter, I see Dan mentioned the drive gear needs to be swapped out. Does the parts store have these (what part # or what to ask for ? ) The gear on my starter looked ok when I had it apart but not sure if my "Special starting procedure" has worn it down any in the last couple of months, if it is ok would it fit the Colt starter ?
Any advise would be appreciated,
Thanks,
Patrick
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
2020 CATERPILLAR 299D3 XE SKID STEER (A62129)
2020 CATERPILLAR...
Knapheide Service Bed (A61165)
Knapheide Service...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
2023 Deere 325G (A60462)
2023 Deere 325G...
207272 (A52708)
207272 (A52708)
