Getting lazy now
/ Getting lazy now
So I started thinking about this again. Does anyone know where to get parts like these that might be adapted to the PT? Any idea what these specific hyd. couplers are even called? Any idea of the costs?
/ Getting lazy now #4
I guess I am not understanding what you want to do? Doesn't your PT already have a hydraulically operated quick attach system?
/ Getting lazy now #5
IIRC, the system referred to in this thread also has automatic hydraulic couplings. 'Twould be nice to have.
/ Getting lazy now #6
They still need some lackey to wipe the fittings off before hookup. It might be a good idea for some things. You could probably build something like that with some break away hydraulic connectors.
/ Getting lazy now #7
Ahh, so it connects the hydraulics automatically, too? That would be cool, but probably too expensive for average homeowner. Maybe not for contractor.
/ Getting lazy now #8
I have a friend who designed one these for his farm tractor. He loves it, and it works well. He has a representative selling it in Europe, but when I looked into it for him in the US market, there wasn't enough interest by the big producers and large scale farmers, who tend to have a tractor per implement, and where implement changes aren't common- unlike PT owners...
All the best,
Peter
/ Getting lazy now
Thought I would bring this to the top because I found a link to a video of what I was talking about when I first posted this thread.
HORST WELDING | Video Gallery
How slick is that and wouldn't it be great on the PT
/ Getting lazy now #10
So you think Surplus center has that kind of connectors avail? WOW is all I can say...
Maybe I will break my arms off the tractor with my new cylinders and redesign a hole new front end. Then again, maybe I will win the lotto and disappear to a tropical island to spend the rest of my life.
/ Getting lazy now #11
6 words I hate to ask myself....
I wonder how much that costs? :(
Really neat, though. :)
/ Getting lazy now #12
No, and you can bet big bucks are involved. One drawback is keeping them clean while uncoupled.
Here are some auto couplers.
http://www.enerpac.com/files/pdf/WCA_WPA_E214US.pdf
YouTube - engcon EC-Oil quick hitch with automatic hydraulic couplings
No, our machines are not that large, but you can see the convenience of the coupler system.
It would almost seem like that one could adapt the flat face couplers by removing the sleeve and mounting in a block with guide pins and use a small hyd cylinder to press the male and female couplers together.
In the first link, it looks like the system is coupled and locked by the locking pin being pushed in. Just my observation.
/ Getting lazy now #13
These are always fun to see. Thanks for sharing them.
The Horst welding version is pretty complex, perhaps too complex. I would worry that in its current version that it isn't all that tolerant of dirt/gravel. Personally, I like to see designs wherein the act of coupling locks the hydraulics as its last step. i.e. Last to open, first to close.
I know an inventor who had a variation on the EngCon quick hitch. He had designed it for his own farm equipment, exploiting the fact that on the Q/A plate, when the attachment is picked up, the location of the the couplers is known pretty accurately. His Q/A system was a little more triangular, enabling a slightly larger travel of the Q/A plate relative to the attachment prior to engagement, facilitating the last to open, first to close system.
He then used solenoids to multiplex the single hydraulic flow into multiple circuits. To be honest, I don't think he had a design that would have been compatible with a PTO and additional circuits, but it worked well for him. Then again, to be fair my memory isn't what it used to be.
There was talk that JD was going to distribute it in Europe, but I don't know what happened.
When I looked at the US market, it turned out that there are a bunch of these designs out there (in terms of patents), but not so many devices. I think the EngCon video illustrates the utility of the these systems to operators that need multiple implements in short order.
For the PT, you could make one, provided that you either trimmed up the Q/A plates and receivers for a higher precision fit, or used flat face couplers in a spring loaded block to allow for the movement in the plates.
Of course, this brings us back to MossRoads' comment,
"I wonder how much that costs?"
Thanks for sharing the link to video JJ. It is pretty slick.
All the best,
Peter
/ Getting lazy now #16
Years ago, (in a former life) I worked around skidsteers on Hazardous sites where all personel had to be in "moon suits" and even with self-contained air supplies. Such couplers would have been very handy (and worth almost whatever the $$) under those conditions.
As has been mentioned above, considering how jammed up regular locking levers & pins can get in the "real world", I would vote for the KISS concept.
However, the increasing safety interlocks and seat belts/bars on modern SSs and CTLs makes one appreciate the basic simplicity of the PTs. I have been intending, however, to give the quick-lock on my 1845 its own dedicated valve & hose conections so that I do not have to swap the lines out when using my grapple or snowplow. Oh well.....some day!
/ Getting lazy now
Another thing I thought of while at work is that this could, if done right, cut down on the chances of getting a hose pinched.
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2015 Peterbilt Dump Truck (A55973)
2015 Peterbilt...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2017 Rogator RG1300B Dry Fertilizer Applicator (A61307)
2017 Rogator...
Massey Ferguson 9250 (A61307)
Massey Ferguson...
Pallet fork attachment for mini skid steer (A61567)
Pallet fork...
