Skidsteer bucket level indicator
/ Skidsteer bucket level indicator #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Hello All,
My tractors have always had bucket level indicators but the skidsteer does not, for some reason. (Maybe its because you should be a better operator by the time you get your hands on a SS) The problem is when using an angling snow plow with a rubber edge. It's setup so that the shoes float the rubber off the ground a fraction of an inch when the pivot pin is plumb. But when the blade is angled and the pivot pin is not plumb, one or the other rubber ends is pushed into the ground and wears very quickly. You can't see it from the cab and wouldn't want to get out to look every time you adjusted the curl. How can I make sure the pivot pin is plumb without a bucket level indicator or getting out of the cab each time?
Thanks.
John
/ Skidsteer bucket level indicator #2
You could make or have maded a clamp on 2 piece indicator ,with on on the cylinder rod and the other on the barrel of the cylinder when the two are aligned then you are in the position you wanted.
CGS,
That should work theoretically. Since one end can't be mounted on the cylinder rod without being peeled off during retraction, the assembly would have to span all the way from the rod clevis to the cylinder body, which might be a little unwieldy. I had such a setup from the factory on some top and tilt cylinders- the idea being that you could use them as a visual reference system to return to a preset position. Eventually they fell off. But with better engineering...
Thanks
John
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
2019 CATERPILLAR 279D SKID STEER (A64279)
2019 CATERPILLAR...
John Deere 4440 (A64119)
John Deere 4440...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2009 Caterpillar 345D Hydraulic Excavator (A61572)
2009 Caterpillar...
