block heater install on b2400
/ block heater install on b2400 #1
tomf
Nebraska
Kubota B2400 HST
Anyone install a block heater on a b2400? Does it go in engine block just above the water line return replacing part 050 in attached pdf file? Anything else of which I should be aware? Thanks tomf
  • B2400 engine block.pdf
/ block heater install on b2400 #2
Correct, part 50 becomes a paperweight after the install. Drain the radiator fluid and flush the system while you're at it. Wrap the new heater threads with 2 wraps of teflon tape to reduce the potential for drips.
I did a block heater on my 2710 about 3 weeks ago and it went so smoothly I thought sure I'd forgotten something. Of course it was about 15 degrees that day out in the barn, which was sort of nice...
Thanks, I'll let everyone know how it goes. tomf
/ block heater install on b2400 #5
Great! Now I know what I forgot...
I went solely with the tape. I read numerous threads and noted the problems that others have had - including an alleged bad batch of heaters floating around several years ago. Have to admit, though, that it was sort of hard to torque the heater plug with my fingers crossed. No leaks yet.
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
LADDERS (A68842)
LADDERS (A68842)
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
1996 Volvo (A64911)
1996 Volvo (A64911)
