Rear fender spash guards
/ Rear fender spash guards #1
ilmoman
Salem IL.
John Deere 3320
I have a new 3320 and am wanting to put on some fender splash guards but I didnt want to spend what JD wants for OEM guards does anyone know of an aftermarket source for these? I have tryed to Google it and dont come up with anything. Thanks
/ Rear fender spash guards #2
Welcome to the forum.
What is Deere asking for them?
Do you have a part no. ?
JD is asking around $250.00 for the set. I dont have the part # right now I would have to go to JD.com and get it again. My dealer wouldnt come down from that price and I have checked at two different dealers. Thanks
/ Rear fender spash guards #4
I knew there was some reason I did not buy them LOL! I would imagiine you could fabricate your own?
/ Rear fender spash guards #5
Does that include the complete unit...front fender, guard, and brackets?
For a set, price seems right. If just a flap to attach to the front fenders, then it is too high. IMO :)
Whoops! Didn't read the title very well.
/ Rear fender spash guards #7
I assume the $250 price is for the rear guards. I think the front wheel covers are nearly 2x that.
Rear fender extension kit
The open station extensions will probably look nearly the same. The list price of $228 is the same as the cab version.
Trying to fabricate your own is probably not going to be easy or work as well. You should be aware, that the gaurds will probably still not cover the entire tire. Throwing mud will still be and issue, probably just less with the extensions. You will still also get mud from the back of the tire behind the fender flinging it forward.
I found a picture of the front fenders. List price $458.
Front fender kit (3000 TWENTY Series)
/ Rear fender spash guards #8
Looking at the image from the JD site, those rear fender extensions don't appear to be very wide - a couple of inches maybe?
Would something like this work?
JC Whitney has a variety of fender flare material (up to about 3 inches wide) used to protect vehicle fenders while off-roading.
If this link will work, go to JC Whitney site and use the search term "Fender Flares".
Rubber Fender Extensions Fender Flares - JCWhitney
Hope this helps,
-John
/ Rear fender spash guards #9
Front fender kit
Front fender kit
The front fender kit provides protection to cab glass or the operator station from mud and debris. This kit contains two fenders, mounting brackets, and mounting hardware.
Compatible with cab and open-station models.
Code Bundle Description
LVB25686 Front fender kit (3000 TWENTY Series)
Note: Not compatible with mid-mount mower.
Last Updated : 10-Aug-2009
Hmmm, JD states the kit is not compatible with mmm. I have the front fenders on my 2007 JD 3720 cab tractor with mmm and have no problems whatsoever. Maybe they changed design since then.
/ Rear fender spash guards #10
The compatibilty with the MMM may be with the new auto connect deck. Looks like the bottom of the guard might hit the front of the deck while driving over it.
$250 for two small strips of plastic for the rear is crazy. I know Deere has to make money but that is just nuts!
/ Rear fender spash guards #11
Riding a Deere is like riding a Harley.....cost wise I mean:p
/ Rear fender spash guards #12
You can make front fenders out of a 'black' 55-gallon plastic drum.
Just cut out your length & width you want.
/ Rear fender spash guards #13
I suspect you are right about the non-compatibility with the newer auto connect deck. My mmm is the older 7 Iron 72" deck.
I bought the rear fender extensions and front fender/mud guards when purchasing the tractor new so I got about 17.5 % off with the package but that is still way too much.
/ Rear fender spash guards #14
Front fender kit
Front fender kit
Hmmm, JD states the kit is not compatible with MMM. I have the front fenders on my 2007 JD 3720 cab tractor with MMM and have no problems whatsoever. Maybe they changed design since then.
They state the same in the manuals about the Turf Specials and I have been running them without issue and any rubbing on the MMM.
/ Rear fender spash guards #15
No kidding and then either purchase the JD brackets or fabricate your own.
Thanks guys I didnt even think about the rubber fender guards for a pu or jeep that would work and not cost anywhere close to what JD wants for them. I was only wanting the rear guards but thanks for the imfo on the front fenders. They would work fine for me I only have a rear finish mower not a mid mount. ILMOMAN
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2012 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2012 VOLVO VNL 6X4...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
1990 FRUEHAUF 53' DRY VAN TRAILER (A64280)
1990 FRUEHAUF 53'...
GYRO-TRAC (A65053)
GYRO-TRAC (A65053)
