Adding External Hydraulics to a JD 870
/ Adding External Hydraulics to a JD 870 #1
terry.dinerman
Gold Member
"The Old Goat Ranch" Grimes County, Texas
1990 - JD 870
Hello Neighbors!
Has anyone added external hydraulics to their 870 and can you share a few pointers?
My 870 does not currently have any external hydraulics or a FEL.
My main intent is to drive a hydraulic top-n-tilt tho I would like to have enough capacity to serve a log-splitter in the future....
Be Safe!
Terry
/ Adding External Hydraulics to a JD 870 #2
Terry,
The easiest way to get it set up to to try to find the Power Beyond/Rear Auxiliary kit for your machine. With this you can plumb in a new joystick valve to operate the TnT cylinders. The part number should be BM18010. Because of the banjo type fittings used on the tractor, getting hoses made locally may be very difficult-thats I why I am suggesting the kit as a good place to start.
Also, you need to figure out if it worth it money wise to you, this will not be a inexpensive upgrade:
PB kit>$250 or so
Joystick Valve>$200
TnT Cylinders>$300-$400
Hoses, fittings, misc.>$200-$300
Terry,
PB kit>$250 or so
Joystick Valve>$200
KennyD-
From the reactions I've got from the area JD dealers, the "Power Beyond" kit should be named the "Priced Beyond" kit...apparently an older tractor like mine requires gold plated fittings, and diamond valves...
So - I am going to come up with a simpler and less expensive plan...
Since a splitter is a long-term dream, and I really NEED to be able to adjust my box-blade and forks a little more easily, my needs are quite minimal.
After scouting all the "Toplink" threads, I would like ask you and the rest of the sages for comments on the attached design for a Manual Hydraulic Toplink...
I have a first class junque-yard nearby with a nice selection of cylinders and valves, some VERY heavy duty , and at popular prices too...
Design Considerations:
  • This is a single acting design utilizing a "cylinder of opportunity" with the appropriate diameter, length and end fittings controlled by a 5000psi ball valve...you can "feather" the flow or dump the load as you choose.
  • A pipe plug filter / breather is installed on the rod end to convert the cylinder to single action.
  • I chose to place the oil on the topside of the cylinder in expectation of shock loading from the box-blade or other ground engaging implements hitting roots or rocks. It is my understanding that in single action cylinders, putting an oil column into compression is more desirable than creating a vacuum during shock loading.
  • Low pressure hydraulic return hose leads to the bottom of a non-pressurized reservoir constructed of 2" galvanized pipe and pipe caps. Reservoir size is dependent on a volume of 125% the expected extended volume of the cylinder.
  • The reservoir will be "U" bolted to the ROP frame above the level of the valve.
  • The caps will be drilled and threaded to accept NPT fittings, JIC hose at the bottom and a pipe cap drilled as a filler / breather at the top.
So what do all you "hydro-sages" think?
Be Safe!
Terry
/ Adding External Hydraulics to a JD 870 #4
Terry, I just do not see how having a SA cylinder on the T/L will be helpful. I do applaud you ingenuity though I just do not see it as being practical.
I have another avenue for you to try...Contact Woods Equipment and see if they will sell you a kit...that have a backhoe that fits your machine, so they must have a way to tap into the hydraulics to operate it. HERE is link to the subframe manual, I could not find one for the hydraulics though...
What did JD want for the PB kit?
I told you it was not going to be cheap;)
KennyD-
The only dealer that has responded so far wanted $395 + tax and shipping...searches on the Net have proved fruitless...
The price for this piece of the puzzle alone is way more than I want to spend for the entire setup...cest la guerre...
This is one of the issues you face buying an older but well-loved tractor....I can't blame JD...parts for this tractor have been gathering dust since 1990...and supply dictates demand...
So - now that I have had a reality check, all I really want to do is adjust the length of the toplink without leaving the seat.
The three implements I want to use this on will all adjust in the same fashion...lower via gravity and raise by dropping the hitch and rolling forward to adjust the angle...the only real gray area in this plan I anticipate in this plan is "Hold" under load being dependent on the seals in the cylinder...
When a load is "hanging" from the toplink, the ram will be in tension, creating a vacuum in the bore...the seals may leak by...
Using salvage parts, I am shooting for a budget $100 +/- to put this together...my favorite yard has racks full of possible materials...I just have to be home from work to get to it...(I am in West Africa as I write this)
Anyway...if it works...Great!
If it fails...I have a cylinder to hook up to a PB kit...or build something else out of....and I stayed out of my Precious Brides hair for a few hours fabricating and testing it...
So I believe I will give my gizmo a try...every once in a while I surprise myself...and it really bugs Precious Bride when I actually use some "treasure" from my junquepile / box / drawer / rack / etc for something useful...
Be Safe!
Terry
/ Adding External Hydraulics to a JD 870 #6
Good luck Terry...Please post back with your progress.
/ Adding External Hydraulics to a JD 870 #7
KennyD-
Be Safe!
Terry
Your thinking is close, maybe if you hooked the 2 ports together with a valve in the middle, and with an additional valve on one side or the other teed to the reservoir. Bleed all the air out, then the cylinder would be solid, and you would not have to deal with a low pressure condition drawing air in past the rings on the piston. I haven't masterd computer drawing, so I hope you can envision it.
Harold (newbee)
Harold (newbee)
Harold-
Excellent!
Your suggestions satisfy several of the shortcomings in my design...with oil on both sides of the piston, closing the two valves will lock the ram up tightly...This also addresses the issues raised due to the smaller volume of the rod side of the cylinder and giving me use of the full length of the ram.
A much smaller reservoir would be needed now as well...with the bulk of the oil cycling from one side of the piston to the other...and any air that may enter the system will naturally gravitate to the reservoir
When I sketched this up, I also noted that it would be easy to "gang" the valve handles, and also extend them....making it even more convenient to reach this gizmo from the drivers seat...
Thanks for your ideas! I can't wait to get home and give this a try....
Be Safe!
Terry
/ Adding External Hydraulics to a JD 870 #9
What you could do is buy a priority valve and install it before your steering valve and then adjust it so you have enough to steer. Then run a hose from the 2nd output to the valve of your choice and then plumb in the lines. You shouldn't need a very big priority valve, so I would guess a new one could be had for under $70, then its just the cost for lines and the control valve and the TNT cylinder.
There are days when I wish I had power steering...
Be Safe!
Terry
/ Adding External Hydraulics to a JD 870 #11
Didnt see that coming, I looked at an 850 w/o PS and akst around, I was told I should have power steering esp. with a loader.
I didnt know 870s could be had w/o it.
/ Adding External Hydraulics to a JD 870 #12
Glad if my .02 might of been worth .10
May God bless your endeavors
Harold
/ Adding External Hydraulics to a JD 870 #13
Harold-
Excellent!
Be Safe!
Terry
That idea looks like it might just work. Let us know how it turns out when you get back.
/ Adding External Hydraulics to a JD 870 #14
This set-up will only let you lengthen the top link from the seat. You will not have a powered way of shortening it. You are going to have to manually collapse the cylinder. Depending on the seals this might be ok by itself, but with an implement on the 3 point that might be a whole lot of fun.
You can use a single acting cylinder on a top link, I've done it. Power retract, gravity or armstrong extend. It works ok, but still requires a connection to the tractor's hyd system and a single acting valve. The only reason I did it was b/c the single acting valve was already on the tractor from some previous loader or blade that was long gone.
Dinerman, Do you have the shop manuals for the 870? They normally show the PB and SCV schematics and port locations. Often a port inside the tractor valve needs plugged also. That sounds far worse than it really is. You can get hoses or metal lines made with the banjo fittings and you can get valves numerous places. I'd still guess you're looking at a considerable amount of $ to complete.
2019 KENWORTH T880 TRI-DRIVE HYDROVAC TRK (A67714)
2019 KENWORTH T880...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A68183)
2008 Allmand...
2015 Ford F-250 Ext. Cab Animal Control Service Truck (A66736)
2015 Ford F-250...
PALLET OF 2 SHOP VACS AND SHOP BROOMS (A67714)
PALLET OF 2 SHOP...
2009 FORD E-150 CARGO VAN (A66091)
2009 FORD E-150...
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
