Yanmar 1500 temp gauge
/ Yanmar 1500 temp gauge #1
jduggan0318
I just purchased a Yanmar 1500 and am happy with the tractor.
I was just wondering if I should add on a temp gauge from Hoye.
My dash is pretty full with turn signal,horn and light switch along with the warning lights.
If I use the bracket with the gauge on the website it seems like it would stick out pretty far.
As for putting it on the left side I don't think that would work because it is tight enough getting on and off the tractor
Does anyone have pictures of how they did it on a 1500?
Thanks,
Jeremy
/ Yanmar 1500 temp gauge #2
Thanks,
Jeremy
Just be aware that since the YM1500 has no water pump, don't let it scare you when you see the temp go up to 240 - 250 degrees or so.
Danny
/ Yanmar 1500 temp gauge #3
This is how I mounted mind on my 1500.
/ Yanmar 1500 temp gauge #4
I got rid of the idiot lights and put in a voltmeter, temp, and oil press gauges. I'll attach a photo of my 1500's dash. I just used a set of small SunPro gauges I found at AutoZone.
2017 DITCH WITCH JT20 DIRECTIONAL BORING MACHINE (A63276)
2017 DITCH WITCH...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
2019 BOBCAT E45 EXCAVATOR (A63276)
2019 BOBCAT E45...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
