New Trailer
/ New Trailer #1
thulstein
I am looking for a new dump trailer. 14000lb with all the extras, i have a trailer from midsota mfg and i think they are by far the best. I was wondering if there are any trailers that compare to them. Please dont post something like a PJ or something of that lower end sort these are very nice trailers.
/ New Trailer #3
I bought mine here. They are a steel fabrication company that makes their own trailers. Powder coated locally, heavy hydraulics. I went there to pick mine up and got the tour. Quite a bit cheaper buying direct from the people that manufacture it. Their primary business is (was?) making components for RV industry, but I'm guessing that's tanked.
/ New Trailer #4
What kind of axles and suspension do they use ??
I see a lot of talk on this forum about how nice the trailer looks- but I have not seen photos or any discussion on the "meat of the trailer" which are the axles and the type of suspension.
We have many equipment and enclosed trailers for work and we finally got rid of the last spring suspension- thank goodness
IMO - Torsion suspension and ez-lube spindles are the only way to go in the long run.
/ New Trailer #6
Hillsboro dump trailers are top notch !!
/ New Trailer #7
I don't know where you are located, but there is a manufacturer in Eastern Iowa that I think makes a very nice trailer. I'm not sure how far there dealer network goes. This is there website: dump toc
I have the 14' 14k low profile bumper pull. It is 10ga construction throughout, 5 ton scissor hoist, 3-way gate. Might want to take a look depending upon your location.
Here are a couple pics of mine:
Link 1
Link 2
/ New Trailer #8
Biggest problem with Torsion axles is they have no way of balancing the load like a tandem or tri axle sprigged trailer with load levelers. We saw lots of boat trailers in the late 90's to about 2004 with torsion axles then they went back to conventional spring setups. I also see more blown tires, I am guessing this is due to overloading of a individual axle, on torsion axles versus spring axles on the 75 or so trailers I pull.
Chris
/ New Trailer #9
Biggest problem with Torsion axles is they have no way of balancing the load like a tandem or tri axle sprigged trailer with load levelers. We say lots of boat trailers in the late 90's to about 2004 with torsion axles then they went back to conventional spring setups. I also see more blown tires, I am guessing this is due to overloading of a individual axle, on torsion axles versus spring axles on the 75 or so trailers I pull.
I would agree on a boat trailer- where the load is basically static ( if its in the bunks- it is likely loaded properly).
Equipment trailers can be loaded in a multitude of configurations- the operator of the trailer and tow vehicle should load the trailer correctly with 10-15% on the tongue and tow the trailer flat. If a trailer is not towed flat you put a lot of stress on the axle(s) and tires- IMO this is largest single failure of tires other than under inflatation and under rated tires for the load and trailer.
/ New Trailer #10
So what's wrong with a PJ? I own/operate a landscaping company with seven different trailers. Of the seven, two are PJ's. I have never had a problem with one and when I buy a new trailer it will be a PJ. I don't understand your comment.
/ New Trailer #11
My dump has Torsions (Moritz) and here I'm right with Dpilot on this one. Lack of load share ability and a baby buggy ride when its heavy. Real glad my equipment trailer doesn't have torsion. I think for a boat 24' and under they are a great soft ride but for equipment or dumps I prefer spring.
/ New Trailer #12
Link 1
Link 2
Ditto
B & B makes an excellent trailer.
/ New Trailer #13
/ New Trailer #14
I wondered about this comment too. I've got two PJ's and they're great trailers.
Who knew there were trailer snobs.:confused:
Matt
/ New Trailer #15
DiamondPilot and others should appreciate this. I was watching a Discovery Channel HD Theater show called 'American Craftsman' and they highlighted Van Dam Woodcraft custom boats www.vandamboats.com and the 'Sempre Avanti' (Ever Forward) boat.
The trailer shown was custom made for the boat. On the way from Michigan to Wisconsin, the trailer's rear axle snapped in half at the mid point. Fortunately no one was hurt and the boat was not damaged. A close up of the axle showed it was made of two pieces of square tubing welded in the middle with no splice plug or sleeve. I don't know who made the trailer; but somebody deserves a good butt chewing over being that cheap. The name on the trailer is the boat dealer/broker, not the trailer manufacturer.
/ New Trailer #16
That is a nice chunk of wood! A fellow in a Wyoming community rebuilds and restores Criss- Craft boats- they are timeless and classic pieces of art!
/ New Trailer #17
That is pretty stupid. The only other axles I have ever seen spliced were Mobil Home Axles and they put a 12" outer sleeve on them.
Chris
/ New Trailer #18
I don't think torsion axles would work good in the woods where you have extreme high and low spots. Alot of pressure is exerted on the rubber flange from weight as well as the twisting motion. I have a 3500# torsion on my utility trailer that is used on the road I couldn't be happier with.
The dump trailer I'm planning to buy or build will have spring axles for durability.
/ New Trailer #19
...I don't think torsion axles would work good in the woods where you have extreme high and low spots..... .
That is the beauty of torsion axles- we use torsion axles in a off road setting all the time- We build and maintain snowmoble and ATV trails in the Rocky Mountians - hence the handle.;)
/ New Trailer #20
Take a look at CornPro Trailers. Excellent quality and use American made parts.... like Dexter axles. They have a website.
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2020 Freightliner M2 106 Altec LR7-56 56ft Forestry Bucket Truck (A61573)
2020 Freightliner...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
