3PH lower arms died
/ 3PH lower arms died #1
patrick_g
Elite Member
South Central OK
Kubota Grand L-4610HSTC
So I'm driving across a pasture through the snow (left over from our white Christmas) with the brush hog/hay handling counter weight up in the air and hit an irregularity in the surface contour hidden by the snow. BAM!! the lower arms are suddenly fully lowered and inoperative and brush hog is in the dirt preventing the tractor from moving much. I recycled the 3PH raise and lower hydraulic control and got no reaction. The 3PH arms seem totally dead.
Luckily I have Pat's easy change hitch and hydraulic top and tilt so I was able to maneuver the implement sufficiently to get free of it and drive away.
I think this is going to leave a bruise on my wallet. Anyone care to guess what was damaged?
This is not a good time to have the tractor in the shop as I need to put out 2-3 big round bales (1,000-1,200 lbs each) about every other day.
Tractor is Kubota Grand L 4610HSTC (about 40 HP PTO, Hydrostat tranny, and cab.)
Pat
/ 3PH lower arms died #2
You leave us guessing what make and model tractor you are having problems with. I'll guess the safety valve for the hitch cylinder circuit opened under shock load and failed to close.
Sorry Rick, I have added Tractor info now.
Pat
/ 3PH lower arms died #4
For starters take a look at the schematic if you have one. Then phone the Service Manager at the Dealer.
Haven't got a clue; but can you lift one arm and see if the other arm follows or if they can be moved independently.
You may have to put the Dodge to use pulling bales.:D
/ 3PH lower arms died #5
A similar thing would happen on our Kubota B1750 when the loader valve got stuck. The loader valve would take all the hydraulic flow and would drop the 3 point and not let it raise. I woudl cycle/jiggle the loader valve handle to get it to free and the 3 point working. Then lube the loader valve slides with a spray or two of WD 40 to keep it freed up.
Too muddy to get the dodge to the hay barn without ruining a lot of pasture and dragging bales through the mud driving backwards using the winch line would not be among the first few choices.
I fear some sort of catastrophic failure since the drop of the arms coincided with the tractor taking a good bump from uneven terrain hidden under the snow. I'll try wiggling all the controls just in case... wouldn't want to pass up a trivial fix to spend $ and time at the dealer and driving 70 miles RT in the weather we are having if not needed.
I don't recall seeing schematics for the hydraulics. I'll call the dealer shop and see if they have a clue.
Pat
/ 3PH lower arms died #7
Do you have a knob under your seat (between your knees) to adjust the speed of the 3pt hitch? Check to see if that got moved . Also might have a little moisture in the hydro oil that froze up, get it in, warm it up, change hydro oil and filters. A little ice can go a long way to ruin your day when it's in the wrong place !
Yes, I have such a knob and it takes many revolutions to go from max to min. It is unlikely(nearly impossible) it would just accidentally get turned many revolutions.
Every thing was working normally, I put out 3 bales of hay using the FEL with hay spike and was just transiting a pasture when I banged a bump pretty hard. Seems like something broke but it could be a hydraulic malfunction.
Pat
/ 3PH lower arms died #9
PatrickG
I had my old L175 hydraulic lift apart to replace the seals and they are pretty robust piston/arm setup that I find it hard to beleive it would shear the pin. Its not real difficult to remove the top but I would take off the oil fill port and take a look inside before removing the top.
Here is a link to Messicks parts list for your tractor - you will see the roll pin in the shaft but to shear that would take a significant upward thrust on the 3PT (versus the typcial downward push to raise) to shear that pin.
Kubota L4610DT-HST-C Parts Diagrams
There is a draft control feedback lever that could be the culprit too.. GOod luck and I hope you have a warm place to work!
/ 3PH lower arms died #10
With the shock load issue.. I'd have to ditto what Rick said about the safety valve.
that thing got an inspection port so you can see into /under the lift cover with a telescoping mirror on a stick.. that and a hyds sceematic and you should be able to see where oil is going out.. and what that means.
soundguy
/ 3PH lower arms died #11
I have heard of this blowing a safety valve or even the piston seals on the 3 point. I am afraid you are going to have to drop the BH and get the tractor in the shop. Looks like you are going to be tearing apart the lift box.
One other thought. Did you BH go up in the air higher than normally lifted by the 3 point? If so it over extended itself and the piston came out of the bore. When it came back down it tore he seals. My buddy did this with a tractor that was 15 minutes old. He could not get it off his trailer with the BH on so he had another guy lift the BH with a FEL beyond lift capacity. When he got it off the trailer it would not lift or hold a position.
Chris
/ 3PH lower arms died #12
I've heard of some chinese tractors having a piston overextend.
I've also opened up some machines to see a piston holed with a shock load.
need to see where the 'leak' is coming from...
soundguy
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
LEEBOY 8510C ASPHALT PAVER (A64279)
LEEBOY 8510C...
2011 Cadillac Escalade 4x4 Ext. Cab Pickup Truck (A61573)
2011 Cadillac...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
