Power feed
/ Power feed #1
paul dyar
Anderson S.C.
TC33DA
It is my understanding that you have to run a 4 wire cable now. Is the old 3 wire not safe? Is the power co. going to change all the old power feeds?
Paul
/ Power feed #2
4 wire only after the first switch.. 3 wire is still used from the service head to this switch.. At least that is how I read the code..
/ Power feed #3
That is correct. Just so happens I had the exact same discussion with the electrical code inspector yesterday. 3 wire entrance cable from pole to meter to service panel/breaker, 4 wire from breaker in main panel to any subfeed panel. A second breaker/switch is not required in subpanel for protection but is recommended for a local disconnect.
/ Power feed #4
Old stuff that followed the code the year it was installed is grandfathered in, don't need to change old feeds.
The 4 wire design - done properly! - makes the ground circut much safer & more reliable. We all hope we never actually use that wire, it is only there for safety, but if wired up properly it can really save a building or a life if something bad happens.
The old way of doing 3 wires & a seperate groundrad at each building allows for some electrical differences between the buildings, and this can set up odd backfeeds & eddies along waterpipe, telephone wires, etc.
Both ways work; the 4 wire way works a bit safer.
--->Paul
2007 INTERNATIONAL 7600 6X4 T/A CONCRETE TRUCK (A66091)
2007 INTERNATIONAL...
2022 EZ-GO ELITE...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
2022 EZ-GO ELITE...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
