2305 Curtis cab
/ 2305 Curtis cab #41
I believe the 2210 and 2305 Curtis cabs are the same. I've had my curtis soft side for 6 years now. Its been a great cab has plenty of room and good visibility.
I did add a radio and a cable operated chute deflector adjuster howdayado.
I didn't like the heat output so I changed the radiator fan to an electric fan with a pwm controller to keep the coolant temp above 180 in the winter.
My brother inlaw has my old garden tractor with a Original Tractor Cab that I put on back in 93. It's held up very well.
/ 2305 Curtis cab #42
Hi Dalejr! If you read the post I send to Diz, the prize and options are there. The first time you install it, it takes about 3 hr. You have to make your first heater and electrical connection and your primary bracket which will stay in place once you removed your cab. I used a pulley attach to the ceiling to removed it and it takes about 1hr to do the job. I stored it back on its original pallet and leave it in my garage for the summer. The bracket to removed it is included with the cab. As for the ac, I don't know, not an option that I needed, but I think they do have it. Check it out on there web site ROPS and Non-ROPS tractor cabs, canopies, and guards for all popular brands - Jodale Perry Corporation . Do I regret it, absolutely not, best moved I made, after my 2305 of course.;)
After a very very quick discussion with my wife, I would like to bring a rectification to my last post.:eek: It should have said '' Do I regret it, absolutely not, best moved I made, after my WIFE and then my 2305 of course''. There now I can keep my john deere.:D
/ 2305 Curtis cab #44
Thank you Kennyd! I found this site by searching on google, because of a vibration problem on a drive shaft for my 47'' blower. Find all the answers I needed on this forum. Receive great help from Dale1995. Great forum, Great people. Henri
/ 2305 Curtis cab #45
Labrat - or anyone else w/ a curtis soft side on a 2210/2305 - any issues w/ the soft rear window? I'm about to order one of these and contemplating the hard rear panel instead of the soft one.
And labrat - not enough heat stock? Did you have your fancy temp gauge in at that point? If so, what was the coolant temp? Since I stole your temp gauge idea, I know I get coolant in the 150s up at 2900 rpms, at least w/ ambient temps in the 40s.
Thanks!
/ 2305 Curtis cab #46
One more thing - anyone have any problems w/ The Green Dealer
I can't find a local dealer willing to budge from full retail on these things, so they are the best option I've found so far.
/ 2305 Curtis cab #47
Diz,
I did go to TSC and buy a couple of fiberglass rods and put them above and below the rear window, when the wind blows it pushes the window into your back.
The idi engines use a 160deg thermostat so the pre chambers in the cylinder heads don't crack. If you start an idi engine and go to full engine load before you get coolant flow the pre chambers can over temp and crack.
I also found that the JD fan moves so much air that it actually super cools the engine block. When the temp drops below 15deg the engine temp won't get above 140deg
I also cut some carpet to put under the seat to block the cold air from coming up through the cutouts for the control levers.
Let me know if you want pics of anything.
/ 2305 Curtis cab #48
Yeah it probably doesn't get down below 0 very often in Japan...
Good call on the fiberglass bows! Thanks Labrat.
/ 2305 Curtis cab #49
Ordered a curtis on Friday, and just got the call - Curtis pushed back ship date to mid-late Jan. So by the time I get it and install it, winter's nearing an end. Sigh.
/ 2305 Curtis cab
diz:
I think you'll find it was worth the wait.
Just cleared my driveway for the second time today with the cab/heater on. Temperature hasn't gotten lower than the high 20's F, and we've only gotten about 6" snow, but now, instead of dreading the ordeal, I actually look forward to it!
/ 2305 Curtis cab #51
Actually canceled the order. I'd pay that kind of money if they could get it to me before the real cold comes, but that's a lot of cash for a 6 week wait. Maybe next summer. Thanks all for your input though.
/ 2305 Curtis cab #52
diz:
I agree with Chipsndust, the cab put the fun back in clearing the 400 foot driveway. I too, have done it twice today and will be out a 6 am doing it again. Just grin when I go over to the outlaws place and do their drive way, seeing everyone bundled up with their snow blowers and I go by with my cab.....and a light jacket on...
/ 2305 Curtis cab #53
Hey I'm still on board, I just don't want to wait that long. If anyone knows of a dealer w/ one in stock, PM me. From my calling around though, it doesn't seem like anyone (including Curtis) stocks anything.
/ 2305 Curtis cab #54
Arrived today, woo hoo! Heater didn't make it, but I've got stuff to keep me busy installing the cab for now.
Labrat or anyone else who did this - how did you route the snowblower chute deflector cable into the cab?
Thanks!
/ 2305 Curtis cab
Thanks!
Great news!:D
Sorry I can't help you with the chute, mine is hydraulically controlled.:cool:
We need pics!
/ 2305 Curtis cab #56
Thanks!
I never use the brakes so I ran the cable through the hole in the floor and clamped it to the brake petal.
/ 2305 Curtis cab #57
I have a 2320 but basicly the same cab style, I removed the plastic glass on the left hand side, this was where I also put my heater, so that I would have less "stuff" in the way when I get out of the cab. I also lowered the heater a few inches so that I had room for the cable chute deflector. I thinks that I used 3/16 plate or whatever was the same thickness as the acrylic window it was replacing. I then painted it JD Green and installed it. Looks factory original!:D
/ 2305 Curtis cab #58
bigtiller and others with cabs and heaters....To get just a little hotter water coming to heater. I bought some Pre-Slit Rubber tubular pipe insulation.and covered both lines from side of tractor upto the heater.
If it keeps lines from freezing and Air cond lines coming into your house cold. it should help keep the antifreeze warmer going to the heater.. I never tried mine before I wrapped them. ,but the other evening it was 18 above and I was sweating with a sweatshirt on, a spring type outer jacket ,no gloves. and a JD hat.
Just my 2 cents
Merry Christmas.
Have fun and be safe !!
/ 2305 Curtis cab #59
The coolest mine has been was 45 degrees inside the cab. But that was after dark in the middle of a blizzard. That is when that pic was taken. 12 degrees and sustaned 30 mph winds gusting to 45 mph.
I like my cab!!
/ 2305 Curtis cab #60
Pics so far. That floorboard bolt on the right hand side of the tractor is a pain when you have the diverter valve kit installed. I might just take the easy way out and put the bolt in upside down so the nut is on top.
Thanks for the input on the blower cable guys. Merry Christmas!
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
2008 Isuzu NPR Box Truck, VIN # 4KLB4B1U48J801742 (A65563)
2008 Isuzu NPR Box...
