New discovery on cold start
/ New discovery on cold start #21
Norm, I also have thougt about this? , There has got to be some sort of explanation as to why this is? I know with my kubota it did help sometimes to pull the decompression release lever in order to get it fired up, although this was after I felt I had flood the cylinder and was using this method to help to clear it out, I think by my theory only if an engine is cold and hard to turn over you can release the compression on the cylinder and have it turn over 10-20-seconds the friction created by the rings will help to warm the cylinder walls and when I warm the plugs it makes it that much easier to start, I'm probably wrong but this is only a theory,...
Norm I see you are from Fort Lauderdale not too far from where I lived back in the mid 60's place call Hollywood, up the road from the Hog farm and the Seminole Indian reservation, do you get around that area much? I bet lot of changes over the 40+ years
Obviously a translation error, even in the factory manual. Yep, used to spend a lot of time working in Hollywood and all over the county, repairing cash registers and computers in most of the bars, restaurants and hotels. Been here since '54, worked for NCR Corp. from '61 thru '93.
/ New discovery on cold start #22
Norm,
I bet you have some nice collection of some antique cash registers:D
Did you by any chance remember and Napier's twas my Grand folks used to there all their lives, Gods rest their soles, owned a Large park close to the everglades, they used to scare the Hejj out of me telling me stories about gaters eating kids and stuff, I think this was to keep me away from the canal,:D
/ New discovery on cold start #23
Norm,
If you mean Naples, that's on the west coast, about 75 miles across Alligator Alley. Used to go over there occasionally.
/ New discovery on cold start #25
Thanks guys. It looks like I do have the TS system. I assume you fill the little pot with diesel? Do I fill it everytime, just enough for one start, or fill it up and it just takes a little each time?
/ New discovery on cold start #26
Check it each time you re-fuel the tractor.
I use a plastic turkey baster (giant eyedropper) to fill it since it's impossible to be that precise from a 5 gallon jug.
Some people replace the original reservoir with the self-fueling model used on later Yanmars. The injector return hose goes through the TS reservoir on that version.
The TS element burns out eventually so test it once in a while. Turning the key to TS position should dim the dash lights slightly when it is working properly.
/ New discovery on cold start #27
Just the other day I tested mine--It is so pleasant to see the frost start melting off the outside of the manifold. :D
Mike
/ New discovery on cold start #28
Well I filled the little pot, followed all the instructions, and it fired right up at minus 8C. Don't know if it was working or not, but it started well considering the temperature.
So many thanks for the information.
213324 (A64279)
213324 (A64279)
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
Mack T/A Day Cab Truck Tractor (A64556)
Mack T/A Day Cab...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
12 Ton Hydraulic Bottle Jack (A64557)
12 Ton Hydraulic...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A67148)
2016 FORD TRANSIT...
