shuttle shift kills engine on L3430
/ shuttle shift kills engine on L3430 #1
lindblad
Enging starts in neutral but when I put the shuttle shifter in either forward or reverse, the engine kills like I had turned off the switch. Any ideas?
/ shuttle shift kills engine on L3430 #2
Check the operator presence switch under the seat, it is probably having issues as that is the expected operation if the shuttle leaves neutral without anyone in the seat.
Aaron Z
/ shuttle shift kills engine on L3430 #3
Switch under the seat sounds like good advice. Recently got a L39 & I'm about 135-140 Pounds, when using the loader I have a tendency to lean to the side watching the bucket. The machine would shut off, after about 3 times of that I pulled the switch out, pushed the button in, wrapped electric tape around it, & shoved it back under the seat. Problem solved, don't tell OSHA about it. Ha Ha
/ shuttle shift kills engine on L3430 #4
Make sure you don't have any snow under the seat... That would keep the safety switch from getting it started.. Let us know.. Good luck.
Thanks for the reply. Will not be able to get back to you till after the first of the year but I think you have probably diagnosed my problem
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
2015 John Deere 550 S4 (A64912)
2015 John Deere...
2017 PETERBILT 579 (A67714)
2017 PETERBILT 579...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
2016 FORD TRANSIT 350 PASSENGER VAN (A66091)
2016 FORD TRANSIT...
2025 Future FT-D680 (A64912)
2025 Future...
