Metal pro ironworker
/ Metal pro ironworker #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I am going to buy a metal pro ironworker. I am always building somthing and am getting tired of the mess from cutting with the torch or plasma and then grinding.The punch on it should make making holes a lot quicker also.I can also add an 8" brake to it. It is a 40 ton unit. Does anyone have one. Are you happy or unhappy with it.
Bill
/ Metal pro ironworker #2
I don't have a metal pro, mine is a Scotchman, but you will love having an ironworker. If you do a lot of fabricating, it will save you a lot of time. I probably use the shear the most, with the punch being a close second.
/ Metal pro ironworker #3
I don't have one either, didn't really know what it was till I searched it up, nice, you getting a new one or used, must not be small change.
You have the cadillac of ironworkers. I have a couple of questions for you. Does the metal distort when using the shear. Can you punch and shear aluminum.
Bill
I am buying a factory demo with the shear and punch dies. It is my christmas present to myself. They arent cheap($2800) but if you fabricate alot it will be worth it. It should last a life time.
Bill
/ Metal pro ironworker #6
I have two Scotchman, a 35 ton and a 50 ton. The 50 ton is a 1980 model and works great 35 ton is 1983 also works great. I found both of mine used and got real good deals on them.
The more you use them the more you find you can do with them.
The problem with aluminum is the knives need to be closer than for steel but you can set it up for it.
/ Metal pro ironworker #7
OOOOH, I'm jealous. I never paid much attention to just how versatile these are until I saw one in action. $2800 is nothing to sniff at but that really doesn't sound too bad. I do think one would last a life time and the long term return makes it worth every penny. I have also noticed they bring high dollar at auction so I don't think you will have to worry much about depreciation....like you'd ever sell it!!
Congratulations and enjoy!
/ Metal pro ironworker #8
try searching for "JAWS IV" thats four and EDWARDS iron workers, I have used both and are fine units for price. We started out with the JAWS V which cost about 4300 when NEW 97 or 98, then stepped up to the EDWARDS back in maybe 02 or 03. Both units were good and lasted well we got trade in on the JAWS for 3/4 what we paid and it was pretty used at that point, as we were running production of industrial machinery...
Mark
/ Metal pro ironworker #9
I picked up a 2005 Uni-Hydro about a year ago. Up untill 3 years ago I had never heard of an ironworker. Well it is the handiest little machine. My main project so far has been the construction of a FEL for my BX. It has come in handy for many other smaller projects. I built my own brake for it as you can see in the pics. (click link below)
Bill, needless to say I'am very happy with mine.
I ordered the Ironworker today. I did a little dickering and got them to throw in the punch set if I bought the 8" brake. Now I should be able to create anything my warped mind can think up. I will post some pics when it shows up. Hopefully It will be here by the weekend.
Bill
/ Metal pro ironworker #11
Years ago I use to use an old buffalo I don't know what the tonnage was but the flywheel was over 8' in diameter.
The notcher on the front would go through 1/2 by 8" deep and didn't even slow down.
I all ways wanted one and am envious of you guys.
enjoy them.
tom
/ Metal pro ironworker #12
Where did you order it from if I may ask? I've always wanted one but thought they were much more expensive than you said.
/ Metal pro ironworker #13
Bill
The metal does not distort when shearing. I am pretty fussy about what I cut with it, (no hardened steel), and it cuts cleanly down to 22 ga. sheetmetal. I have even used it to cut cardboard! If you have dull blades, it will distort the edge. I use it for both steel and aluminum. Another handy feature I like is the angle iron shear, Greg
/ Metal pro ironworker #14
That will be a great Christmas present for you, Bill. I drooled over the
Scotchman (or equivalent) units for a while. I have paid for punching,
mostly of 1" holes in 1/2" A36 steel plate. You need 40T for that, and there
is some distortion of the holes. I was looking for a good used deal that
included lots of tools/dies. I eventually decided that I would not use
it enought to justify the cost or floor space in my limited workshop.
Post a photo when you get it.
I bought mine from metal pro Welcome to Metalpro Corporation. They are the manufacturer. Northern tool sells them. If you have on in your area you could pick it up at the storeand save the shipping cost.. I talked to MetalPro today an it ships tomorrow. I should have it Mon. or Tues.
Bill
2001 Ford F-550 Truck, VIN # 1FDAW56F81EC40182 (A65563)
2001 Ford F-550...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
International 490 Disc (A65640)
International 490...
2022 CATERPILLAR 914 WHEEL LOADER (A65053)
2022 CATERPILLAR...
Allmand 8KW Light Tower (A64194)
Allmand 8KW Light...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40XXMJ464379 (A65563)
2021 Kenworth T880...
