Oil & Fuel Fuel Tank Crack
/ Fuel Tank Crack #1
zkurtb
North Idaho
Kubota B7800
Any one ever get a crack in their fuel tank? Happened to me on a former tractor. I noticed diesel smells and eventually the wet on the frame and ground. Was happening even with very low fuel levels, so figured the leak was near the bottom of the tank. From what I could see there were no hoses or fittings near the bottom. So one day I pulled it out to see what was going on. It was quite a bear to get it out. Found the crack shown in the pics.
/ Fuel Tank Crack #2
Is it steel?
Under warranty?
If not
If so drill a small hole at the end of crack clean it up and get it welded
The hole is important to relieve the stress at the end of the crack.
tom
/ Fuel Tank Crack #4
I'd solder it or braze it.
soundguy
/ Fuel Tank Crack #6
Solder will not hold, drill & braze it.
E/S
/ Fuel Tank Crack #8
E/S
Solder will -certaintly- hold it... how many sumps have you soldered?
soundguy
/ Fuel Tank Crack #10
well sir,i would tend to agree with you, since we arent talkin about plastic forks, it does prove nothing. and up to the point i posted, nobody had mentioned the proper precautions, thats why i posted. i would hate to think somebody got hurt because nobody posted the "proper precautions" and they did not know any better. nothing wrong with not knowing, we all got to learn sometime. i took a welding course 35 years ago, and thats one thing the instructor drilled into us nearly everyday, never weld on a closed container without the proper precautions. i sure am sorry to hear about your friend and the mishap with the plastic fork, would have been nice if somebody would have warned him i reckon.
/ Fuel Tank Crack #11
My point was .. just about anything can hurt you.. if you -try- to get hurt.
welding on a closed container holding or recently holding petro products and fumes is -trying- to get hurt, at least in my book.
soundguy
/ Fuel Tank Crack #13
clean it well and soder it with a big sotering iron dont no what they are called they have a bigger head, not one of the wire ones , also sottering irons have no flame much safer, i did it on a jeep tank and it held for me .
/ Fuel Tank Crack #14
hey tom, you are a very lucky man, sorry to hear about your misfortune. one really important thing to note is that, it is not enough to remove the bungs, that does give somewhat of a release but in an actual explosion the air expands so rapidly in most cases the result is still the same. i will be the first to admit, it is not a common thing to have one blow up, but it only takes one time. i am really glad you lived to tell about and are doing well. best regards
/ Fuel Tank Crack #15
Run an airline to it and weld it! Just did a diesel tank like that. Different on a gasoline tank though be careful. On my old Shovel (Harley) I cracked a tank before a run and was eager to ride. A friend of mine said to pipe the exhaust from his bike into the tank and weld it. No oxygen no explosion. Dam if it didn't work, Rode all weekend.
/ Fuel Tank Crack #16
we used to call them soldering coppers.. big copper heat with a wood handle you heated in a fire or with a torch...
soudnguy
/ Fuel Tank Crack #18
soundguy
How many tanks have you soldered and not had re crack?
E/S
/ Fuel Tank Crack #19
As far as I know, -none- of the tanks I've soldered have re-cracked.
Just takes a lil care.. stop the crack, clean it up, flux the heck out of it and lay some lead on it.
soundguy
/ Fuel Tank Crack #20
[QUOTEsaid to pipe the exhaust from his bike into the tank and weld it. No oxygen no explosion. Dam if it didn't work, Rode all weekend.][/QUOTE]
At the proper air/carbon monoxide mixture it is explosive! It would not be considered a proprietary procedure for welding on a closed vessel.:D
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
Bomag Roller (A63689)
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
