Effective PTO HP on a JD 4520 with E-PTO
/ Effective PTO HP on a JD 4520 with E-PTO #1
eepete
Efland, NC
JD 4520, Kubota B21, JD 318
I have a JD 4520 with E-PTO. The tractor has 50 HP on the PTO at the rated engine speed. My questions is what is the HP of the PTO when I have the E-PTO engaged and am at the lower (and correct) engine speed?
Years (decades?) ago, you could get torque curves for engines (torque vs. RPM). As you gear up the PTO for the economy mode, it would have less torque. Combined with reduced engine speed that should mean less power. I suspect the answer to my question will involve wrestling with concepts of torque and horse power.
The event that has triggered this questions is I purchased a SpeeCo PHD that is rated at max PTO of 40 HP. While I normally get good quality and well matched attachments all from my JD dealer, I only need to make 36 6" holes for my next project. I'm sure there will be more holes in the future, seems like every time I use my manual post hole digger I swear it's the last time and it's not. So the PHD decision was a mix of a fit of frugality tempered with the local clay soil and not too big rocks. I am hoping that careful use will make it work and the $600 I saved will be good in the long run.
I've also used my MX6 mower with the e-PTO. It really bogs down the tractor when I engage the PTO, but my dealer says it's OK. I use it like this when I'm effectively "mowing the lawn" and it's all level surface with grass where I'm taking off 4" or so. I've also used the sickle bar in this mode and it seems to have all the power it needs. I use the MX6 in "normal" PTO mode in areas that get cut once a year, and it's great. One pass at 5 MPH and I'm done.
So there's my questions and circumstances that brought it up. TIA.
Pete
/ Effective PTO HP on a JD 4520 with E-PTO #2
Pete,
I have wondered about this too and don't have an answer for you. I have an older Deere 31B phd and have sheared the bolt that holds the auger in place with no damage done to the gearbox or pto driveline. I think that using the e pto setting is a good way to limit the chance of damage though, I would go for it.
I know that Cummins has torque and horsepower curves for most of their industrial engines, don't know about Deere.
Steve
/ Effective PTO HP on a JD 4520 with E-PTO #3
If your 4520 has HST, it is rated at 50 hp. I rarely (ok, never) run a pto driven PHD, at pto speed. I don't use a pto PHD any more, but when I did I typically ran them a low engine rpm and they seemed to dig better, less wobble, can control how fast they dig easier and probably safer to operate. I would rather kill the tractor engine, then break the PHD or replace a shear bolt. Just throttle back your 4520 and you will save your shear bolts, be below your max 40hp for the PHD and it should work good. I don't think e-pto is the solution to reducing power for a PHD.
/ Effective PTO HP on a JD 4520 with E-PTO #4
I agree with using lower engine speeds and find the auger is easier to control.
If he uses the e pto at a low engine speed he will definately lower the torque available to the phd. This is just simple gearing and simple math.
Steve
The normal RPM for the PTO is 2300 (i think) the RPM when using the e-PTO is 1750. The little bit I've been on the tractor, it seems that power seems to drop of fast around 1400 RPM. So the mix of using the e-PTO and running at 1400 to 1500 RPM seems like it will work. And the RPM could go lower if I needed to reduce power more. The fact that both of you run PHD at less than PTO speed is good to know. The lower RPM combined with the e-PTO gearing and I think I'm good to go.
Just for fun I'll ask my dealer to contact Deere Central and get the PTO rating for the PTO when in e-PTO mode. When/if I hear back I'll post the number here.
radman1: I'm curious why you think that the e-PTO is not a good solution to reducing the power to the PHD? I agree with Steve that it seems like a good way to reduce torque/power to the PHD.
Pete
/ Effective PTO HP on a JD 4520 with E-PTO #6
Pete
The e-pto will increase your pto rpm more than you need. I prefer the slower turning auger on the PHD. Say you run the tractor at 1400-1500 rpm engine speed. The e-pto will give you a much faster auger rpm on the PHD than I feel you need. At 1400-1500 engine rpm and in normal pto, you will run the auger slower, and yet be under the max pto hp of 40 recommended by the PHD company.
Most diesel tractors have max pto hp in the 1700-1900 range, depending on the size of the motor. Look at the NE tractor tests. Hp ratings are given at pto speeds of 540 or 1000, depending on the pto shaft/output. However, the max engine hp is at the lower rpms because of the torque/hp curves. This is how the diesel engine can power through tough conditions. Now if the e-pto operates the engine at 1740 rpm, it is probably very near the peak engine/pto hp. I feel it is best to run the PHD at a normal pto setting and at a lower rpm of 1400-1500, get below the hp peak and still have a slow auger rpm on the PHD. However, with lighter duty mowing, run the e-pto to get the 540 rpm for best cut for the mower, and yet save fuel, engine wear, less noise etc.
/ Effective PTO HP on a JD 4520 with E-PTO #7
Some good points by all so far, my idea of low speed is throttled down all the way which on my tractor is around 1250 to 1300 rpm. Next week I should be ready to start a fence project with about 250 to 260 post holes, I will try both the standard and e pto settings to see what works best. I am also looking forward to utilizing the tilt function on my hitch to help plumb the auger.
Steve
/ Effective PTO HP on a JD 4520 with E-PTO #8
Just a note that everybody is already aware of but I'll mention it anyway.
With EPTO being the exception (A mechanical increase in the PTO shaft speed compared to engine speed which reduces torque to the PTO shaft compared to normal PTO operation).
Also, I'm not talking about a dead stop situation where 'kinetic' (my term) horsepower (flywheel/mass effect) can shear things, I'm talking about loading the implement without stopping it.
Reducing the speed doesn't necessarily reduce the ability to shear pins. HP isn't what shears pins, bends tillers, etc. it's torque. The reason we can use HP to rate implements is that they are always rated at 540RPM which means only the torque varies with HP variation. Every 1hp of rating equals about 9.72 ft/lbs of torque. So if you have 10 pto hp available (again, at 540) you have 97.2 ft/lbs of torque at the shaft. go to something like 56 on the 4720 and you have 544 ft/lbs of torque (a sh##load in technical terms) - That's a lot of torque. And realize that will INCREASE slightly as engine speed decreases (Remember the governer will increase the throttle to maintain speed so it shouldn't matter what speed you have the throttle set at).
Most diesel engines actually have more torque when you slow them down a bit from operating speed (Deeres are like this also). If you slow it way down of course you'll reduce the torque, but if you slow it down a little you can actually INCREASE the torque
when it's under load.
This is why as somebody already mentioned a torque curve is helpful for determining the PTO HP and torque at any given RPM.
I heard back from the dealer. He said no one has ever asked that question before. He called Deere and they said that:
"The 540/'540 economy' PTO allows operators to select the engine rpm needed for their PTO application. The economy position provides 540 rpm to the PTO at approximately 70 percent of the engine's normal rated speed. Effective PTO HP in the 540E mode is 65% of the rated PTO HP. The 4520 is 50PTO HP times 65%. The effective HP rating is 32.50PTO HP."
This would also explain why the MX6 _really_ lugs down the tractor, and I have to be at 1900 RPM to start it. The PTO range on that cutter is 30 to 70 HP. So getting back to the PHD the e-PTO at 1500 RPM will probably be perfect for 6" and 9" holes. Sounds like I could use my 15 to 30 HP tiller too (width constraint is the big problem there). Because of it's name, the e-PTO sounds like a fuel saving device but in fact it can let you use a broader range of implements and let you play with PTO speed, much like the PTO speed selector on other tractor brands. The name (e-PTO) might be how you market an old trick to a the new dogs.
Steve: I remember in another post your saying that your idle speed was 1250 to 1300. Mine is 1100. The operator and service manual state it's 1100, and advises that at 600 hours you should "check low engine idle speed". Later, in the service engine section the action to take if it's off is to "see your John Deere dealer. Wonder if this ties in with your computer problems. Just FYI
I'm getting a hydraulic top link top link (ordering it today). That should leave me with only one axis to worry about.... I should be drilling my holes this weekend if the weather co-operates. Look forward to hearing how things work for you.
Pete
/ Effective PTO HP on a JD 4520 with E-PTO #10
You can't run the PHD slow enough, in my opinion. I run mine on a 540 PTO with the engine at idle (44 HP tractor). If I hit something like a root, I get in less trouble this way.
/ Effective PTO HP on a JD 4520 with E-PTO #11
Pete, if your tractor will idle down low try that first in the epto setting. I agree with Radman that the lower speeds are more controllable for phd work. You can bump up the throttle from there to see what works best for you. With a lot of holes to drill you might consider adding some weight to the boom, generally speaking faster penetration is more affected by weight and or pressure rather than the rotation speed.
I will check into the idle speed on my tractor, about a month ago or so the service manager for the dealer came out and jacked up my tractor with all four wheels free and reprogrammed it. You would think he would have adjusted the idle speed at that time, I will have to make sure of exactly what it is when warmed up and give him a call.
Thanks for the info.
edit: I should add that if you find the speed is still too fast then revert to the standard pto mode, you will still be below the 40hp rating.
I've got hard data from Deere, and great advice from Steve, jimgerken and Radman. So now it's time to stop analyzing and start drilling (as soon as the weather cooperates). Thanks to all.
Pete
Update: Got PHD on tractor, played with it a bit. Since the predominant opinion was that slower is better, left PTO in normal gear (Not e-pto) and ran tractor down at 1200 RPM. Digging in the North Carolina red clay was easy, tractor didn't bog down. Speed was not a problem, I slowed it down more than anything by how fast I would drop the rig. Didn't even try the e-pto since the control on the low speed was great. Might do a test hole sometime with e-PTO
Had to pick up the RPM at the end to try to get the dirt out of the hole, and it's an odd dance of higher RPM and lifting the PHD while being sure not to get all the way out of the hole. Still had about 6" of dirt in the bottom, suspect that's just technique I'll have to work on.
The auger would "auger in" by about 2-3 inches, then pop up at this low speed. Might try a few more RPM once I get the hole about 6" deep and see if it still augers in. Not a problem. Tractor size/weight/HP made it all easy. The tractor was in charge, not the PHD.
Thanks to everyone for their advice, it was right on the money. It was a great discussion and good data on E-PTO vs. Normal PTO. I still want to get the torque curves for the engine. Maybe I'll ask my dealer. Now if the ground around here every gets hard again, I've got about 50 holes to dig.
Pete
/ Effective PTO HP on a JD 4520 with E-PTO #14
6" of dirt in the hole at the end is probably a bit more than I would have left when I remove the auger but there is always some left in the bottom. Leave the PHD turning when raising, and raise it slowly and allow the auger enough time to bring up the dirt. You can used hand PHD to remove the loose material at the bottom. Depending on how deep you need the post, you can also just tamp the remaining dirt down tight. If hole is still to deep, throw a little more dirt in and tamp it down. After a few holes and setting posts, you will learn how deep to go with the tractor PHD. My philolosphy is it is easier to dig a little too deep with the PHD rather than have the hole too shallow and then dig out with hand diggers or redrill deeper with tractor PHD.
Thanks for the tips radman1.
This, like many tractor implements, is another learn it in a minute, master it in a lifetime event. 20 seconds is much better than 20 minutes, that's for sure.
I am a little concerned that the task seems a bit boring. After a number of holes, it seems like the same old drill and you get tired of the hole business. Your depression deepens as you feel like you keep going around in circles. And even when you're done it all feels kinda empty. So you pick up the pieces and fill in the empty void, then move one. I love it :D.
Pete
/ Effective PTO HP on a JD 4520 with E-PTO #16
Pete
Anybody ever tell you that you are overly analytical/:eek::D
/ Effective PTO HP on a JD 4520 with E-PTO #17
I like my drill here next to the barn I'm remodeling.
/ Effective PTO HP on a JD 4520 with E-PTO #18
I have a question also about PTO HP requirements for a Tractor i want to buy. I have a new Property that basically requires (at some time in the future) to be Fenced off (lots of post hole digging). and am considering two Tractors to do the Job, but mainly it will be used to do Field Mowing and such. I dont want to buy something that may be underpowered (previous posts) to do any Jobs that arise in the future (stumps, rock moving...). I am looking at a JD 2520 (FEL(300CX?),JD 46 BH, 350 HRS for $17500) or a JD 3720 (FEL(300CX?) 150HRS, dont know price yet). I know the 3720 has at least 20 more HP at the PTO, but is it too much? and would the 2520 be to little? I dont wat to be driving a Monster around (looking like an idiot, lol) for mostly mowing... but i dont wat to find out i should have bought bigger either. Anyone got any ideas on this... could i go in between, a (JD,Kubota) 30/35HP machine maybe? ground that i know of is not bad, pretty earthy. thanks in advance...
ajwren
/ Effective PTO HP on a JD 4520 with E-PTO #19
ajwren
A better description such as the number of acres to mow/brushhog fel tasks would help us help you.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
Mini Skid 6 Way Blade (A56438)
Mini Skid 6 Way...
2015 VOLVO VNL760 SLEEPER (A59905)
2015 VOLVO VNL760...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
DIRT DOG AGR72 GRAPPLE (A60430)
DIRT DOG AGR72...
