Snow Attachments ABS Plastic Pipe Snow Blade Edge
/ ABS Plastic Pipe Snow Blade Edge #1
bp fick
Super Member
Beaver Creek, Northern Michigan
John Deere X390
A number of threads here have traced the trials, successes and foibles of using a piece of PVC on a snow blade. Run it through the table saw, and bang it on. It sure works great over gravel, but easily shattered in cold weather.
Here's why:Quality Control
Some here have suggested ABS plastic as a much better alternative. Here's my photo, clicked on the run, of my newly installed ABS pipe.
What a difference!! It's 15 degrees colder today, mid-teens, and yet, no breaking. Very pleased.
(Although the paint is sure peeling on that blade!)
No doubt HDPE would be even better, but I just couldn't find any in town this morning.
/ ABS Plastic Pipe Snow Blade Edge #2
So help me out...........the purpose?:confused: Is it better than the steel edge on a gravel driveway? If so what diameter ABS pipe did you use?
Purpose- To skid, to prevent moving gravel, especially early in the year before the ground is frozen or in spring during thaws. And no, shoes are not the answer as they too gouge big time. The pipe is slick!! Many guys slit a steel pipe, but plastic is quick and easy.
Diameter. Some use 3". I prefer 1 1/2 inch. Although this particular piece of ABS I was lucky to get at all, and it is 2".
/ ABS Plastic Pipe Snow Blade Edge #4
Just applied mine yesterday. Have to remember not to backdrag! ;). I used 3"
/ ABS Plastic Pipe Snow Blade Edge #5
I can speak to that! I tried yesterday using just the shoes on the blade and tore up the driveway pretty good. It's just not frozen yet and the shoes like to dig up the soft spots of the driveway. My next attempt will be applying 1 1/2" PVC Schedule 80 to the blade.
/ ABS Plastic Pipe Snow Blade Edge #6
Are you using 3" pipe?
Gotta tell ya. The price of ABS is no more than PVC.
Once I had used up my scrap PVC, that was it. I went through 3 yesterday. Enough. I sure as heck wasn't going to buy any just to break it. Read that link above about properties of PVC versus ABS. It is a short read, but very insightful.
Just plowed 3 hours with that ABS and it doesn't have a mark on it. Go to admit, I am impressed.
/ ABS Plastic Pipe Snow Blade Edge #9
OK, I've reviewed the recent posts and haven't seen an explanation. Forgive me if I missed it. I'm currently using schedule 40 and have shattered one piece in three Winters. Not too bad but quite inconvenient in the middle of a storm. I'd like to have an upgrade on stand-by. What is the difference between HDPE and schedule 80? I've called three plumbing supply houses and they seem clueless when I say "High Density Polyethyline" but admit that they have schedule 80. What is the difference?
/ ABS Plastic Pipe Snow Blade Edge #10
After reading the threads about this yesterday, I went home last night and dug out the piece of 3" sch 80 electrical conduit I remembered I had in the top of the garage. Ran it thru the table saw and attempted to beat it onto my bucket. It did not want to go on so I determined I needed a larger gap. Found a 1/4" router bit, that was interested. I finally got it installed and should have taken a pic. The tension of the pipe should hold it on, given the beating it took to get it onto the bucket. Snow started falling here in Rochester NY this morning, can't wait till I get home to see home it works.
The illustration below shows the results of impact tests on ABS and PVC pipe at 32 F. Note, the ABS pipe has a good ductile impression resulting from the impact test. The PVC pipe shattered under the same test conditions:
TOP: ABS PIPE
BOTTOM: PVC PIPE
The impact strength of PVC is only one-half that of ABS at 72 F. And, one-third the strength of ABS at 40 F. The low temperature value of PVC is only 32 F. That is, it has lost its impact strength at this temperature. By comparison, the low temperature value of ABS is minus 40 F.
From MonarchPlastic.com
Schedule XX is a measurement of thickness/gauge basically. Ask a pro, which I am not.
These different plastics vary widely in their abilities and characteristics, strengths, resiliency, impact, shatter temperatures, etc. None of these products were designed for what we are doing with them. :D
That said, PVC is pretty brittle, ABS much, much less so, and HDPE is space-age stuff, but I cannot get my hands on any out here in the sticks!:D:D
I suppose Kevlar, if made into such a pipe would be as strong or stronger than steel itself.
/ ABS Plastic Pipe Snow Blade Edge #13
Thanks BP -- like I said in the other thread, ABS is all I have used , just from being frugal and it's availability -- nice to see it is working out for you. I have used the 1 1/2" up to 3" and settled on 2" in the end.
/ ABS Plastic Pipe Snow Blade Edge #14
Is this stuff available at any local or national chain hardware store/home center?
Studor,
I sure wanna thank you for putting me on to ABS. It is incredible stuff.
As for availability, it supposed to be available at some/most Lowes. I got the only stick in town, but "town" here means hokey little mom & pop hardware store. They said, "We got that piece by mistake. You can have it for $4.00"
It was 10' long!! Woo Hoot!! That is precisely two times my 5' blade.
Thus, my single ABS pipe edge was $2. usd. Come on, how good is that?
/ ABS Plastic Pipe Snow Blade Edge #16
Black ABS sched 40 has been used as drain pipe forever around here -- PVC has only become common in the last 10 or so. Coleman makes ABS canoes that stand up pretty well to abuse -- just a little heavy compared to kevlar:eek:
I think that you should be able to find it at Lowes etc but to be honest I have never looked when I am in the States -- sometimes different codes mean entirely different materials are sold in some markets.
10 feet is the standard length and I think 2" is about $1 a foot or so - have not priced it lately as I had a bunch of scrap pieces:p
/ ABS Plastic Pipe Snow Blade Edge #17
does this also help with the blade digging in and tripping the springs? we got a whopper here in WI. some drifts were 4-5' tall. my biggest problem with my tractor mounted plow on a gravel driveway was that the plow would dig in and trip the springs. it was annoying and slowed me down. i have shoes/skids on and they didn't seem to be the problem.
/ ABS Plastic Pipe Snow Blade Edge #18
Lowe's and the other box stores around here carry ABS. Not nearly the selection as PVC though. I looked at some the other day and noticed the price for ABS was about 30 - 50% higher than PVC. That could be due to old stock that reflects the higher oil prices from last year. I have a partial paved drive, but mostly gravel. I'm curious if it would clear a concrete drive or make a mess.
/ ABS Plastic Pipe Snow Blade Edge #19
I went and bought one length of 3" ABS at Home Hardware this week. They're a national hardware chain in Canada. A "length" was 12 feet, cost was $24.99 + tax.
/ ABS Plastic Pipe Snow Blade Edge #20
Should work just fine unless the snow is really packed or icy --- it should stop the plow from tripping as often if it is tripping because it is catching -- if it trips from weight you need more spring or more angle --JMHO
Grain-O-Vator Silage / Feed Wagon (A66408)
Grain-O-Vator...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
Heavy Duty Car Dolly (A62679)
Heavy Duty Car...
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2021 Ford F-750 Reefer Truck, VIN # 1FDWF7DE6MDF06465 (A65563)
2021 Ford F-750...
