John Deere 3520 with Cab on Order
/ John Deere 3520 with Cab on Order
With the tractor OFF, Try rotating the mid PTO by hand and have someone move the lever untill it falls into place. I had the same problem when I first got my 3520, and this seemed to resolve it. The internal gears may be out of sync.
That did it!!!! Thanks for the information. I also corrected the problem with the Rockshaft Lever Control by loosening the nut some at the Rockshaft housing. I purchased my radio yesterday so now it's time to get it installed.
/ John Deere 3520 with Cab on Order #62
I beg to disagree. This has been discussed many times and there are many different opinions, but I much prefer the PR transmission: great for loader work, more HP to the wheels and PTOs ... Hydro transmissions seem better suited for lawn-mowers needing to go very near obstacles.
I agree. Coming from a 2 spd hydro to a Powershuttle, I will NEVER buy another hydro tractor ever again.
/ John Deere 3520 with Cab on Order #63
Congrats on the new tractor. Is sure is perdy :)
/ John Deere 3520 with Cab on Order #64
Thanks Nuru. It will be a while before I make a decision on wheel extensions. My neighbor is a retired Master Machinist and now works out of a shop at his house. I will probably ask him to build them. I'm thinking 2-3 more inches per side. I have checked out the other threads and they were very helpful.
My first project is installation of the radio. Then I intend on installing a hydraulic top link.
no problem coglesby. I think you probably want to go 6" on both sides for the appropriate increased stability.
/ John Deere 3520 with Cab on Order #65
does anyone know the height of a 3720 0r 3520 cab tractor with industrial r4 tires?? will they go in a 9' door??
thanks!
/ John Deere 3520 with Cab on Order #66
thanks!
Height of 3x20 series with R1 tires and cab is 89.4". Take off 1-2" with R4 tires.
/ John Deere 3520 with Cab on Order #68
not to sound cocky or rude but there is a reason front end loaders dont have clutches . grear drive is better for groud ingagement type work but other than that its a toss up with the hydro having a clear advantage in loader work . as far as the brakes being on the left thats how they are on all back hoes . i love the turnbrakes being on the left it just makes since .
/ John Deere 3520 with Cab on Order #69
thanks!
They will fit in an 8' door no problem with R4's;)
/ John Deere 3520 with Cab on Order #70
Yep, i have Turf Specials on and my unit is 66" - 68" wide with them on and it goes through my shed door with width. but I need 91" of height for clearance for the top.
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
UNUSED X-STAR 250 GALLON FUEL TANK W/ FORK POCKETS (A60430)
UNUSED X-STAR 250...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
