Cordless Impact Driver
/ Cordless Impact Driver #1
bigtiller
Super Member
central Iowa
John Deere 2720 John Deere 3039R John Deere Z545R
What size (volts) do you like best? I have never used one but I want to try them because I use my 18 volt drill all over the shop and house but mostly for driving screws in wood. I am told they are easier on the wrist than a drill. But there are just too many choices and prices out there for me to choose from blindly and thought someone might offer some tips on what to look for or avoid.
/ Cordless Impact Driver #2
I can tell you from experience that the 18V Ryobi is not worth buying. It worked for the first 20-30 1/4" x 6" lag bolts I was driving, but something in the plastic gearing must be going, because it doesn't do as good of a job now.
/ Cordless Impact Driver #3
I have the De Walt 18v driver. I got it because I already had a plethora of other De Walt 18v tools, so I got the impact kit on sale with a a drill and two extra batteries.
It is amazing what these things will drive!
/ Cordless Impact Driver #4
I'm with Kenny. I got mine free via mail-in after my wife bought me the 4 tool kit. I use it more than I do the tools she bought me. I love it. As much as a Cordless Drill improved driving a screw from a screw driver, the impact driver improved it that much more. I love mine. It is the only thing I use now to drive screws.
I say whatever one you already have batteries and chargers for (if you are happy with the performance of those and aren't looking to switch brands).
On a side note. I used this on our camper to lower the stabilizing jacks. It did a great job, but the impact sound resonated off the frame so much:eek:, that I decided I had better switch to the normal cordless drill.:p
/ Cordless Impact Driver #5
I also have the 18V Dewalt. It works great for the few times I have used it. I think the trigger works backward. If you already have batteries and chargers I would by one off E-bay and get the impact only. I found a deal on the impact and case only.
Dan
/ Cordless Impact Driver #6
i've got a 18v ridgid an think its great: i couldn't believe how much faster i could put screws in a new metal roof.
heehaw
/ Cordless Impact Driver #7
I bought a 12 volt bosch impact driver on sale for 69 bucks, it came with twp batteries a 1/2 hr charger and a hard case. It is great for driving screws! Way better than a non-impact drill. The bit dosen't slip on the screw head nearly as easilly, and it's much lighter weight.
/ Cordless Impact Driver #8
We use a lot of the 18V DeWalts impacts at work. I have to say I think they are the best cordless impacts made. I have allways been a Milwaukee fan but DeWalt makes the best impacts by far.
/ Cordless Impact Driver #9
I've had the Makita 18V Lithium Ion set for a year now and I wish I had the impact driver years ago. It is a much much easier tool to drive screws with than the drill driver. I found the Lithium batteries so much lighter and the tools seems to be better balanced than the Dewalt's we have at work. Don't get me wrong I still like the Dewalt stuff.
Steve
/ Cordless Impact Driver #10
For me 18v power is the way to go, and DeWalt is my brand of choice, it's never let me down. As another poster said, if you already have a brand that you like, find an impact that will work with your existing batteries.
/ Cordless Impact Driver #11
The impact driver will drive the screws without camming out of the heads and stripping them out. Get one that will use your batteries and you will be a happy camper. You will never try to drive a screw with a drill again.
My all timer favorite is the Milwaukee v18.
/ Cordless Impact Driver #12
I think I have them all. I like the balance and small weight of the Makita along with the ability to use both 1.5 and 3.0 Amp Hour batteries. The DeWalt is similar in size and performance, it just doesn't feel as compact. The Milwaukee V18 is the KIng Kong of the bunch. It is a little larger,but it has an impressive amount of power and therefore speed. It will flat out outdrive anything else in the 18 volt class buy a wide margin. It almost has to much power for small screws.
I also have the Bosch Lithium Ion 12 volt max/ 10.2 volt impact driver and about 8 batteries. It does a remarkable job for what it is, but the Makita with the 1.5 Amp hour battery is almost as small and is much faster. These are all the Lithium Ion ones I have.
I also have several NiCad versions. I have Craftsman 14.4 and 19.2 volt units. They are hard to beat if cost is a concern. They are very adequet for home owner use, the homeowner style battery capacity is the only drawback along with the aditional weight and bulk of the NiCad battery pack. On the pluss side there are many additional tools that sears sells that use the same battery and the batteries are often obn sale for only about $25 each:D:D:D
One of my favorite NiCad units is a Denali brand sold thru Amazon.com. I bought several of them as bare tools for around $20 each. They work about as well as a Ryoby or a Craftsman with a few advantages. They have a built in led light that shines up on the impact area with its own on and off switch, so you can use it like a flashlight without having to press the trigger. The Battery mount rotates 360 degrees so you can swivil it out of the way to get into tight places. The battery also sems to have a rather large capacity for a consumer grade tool, it holds it charge while stored exceptionally well for a NiCad, and it has a built in charge indicator. All in all it is a very nice unit for very little money.:D:D:D
I think the sensible thing to do is get one that uses the same batteries that you have for your drill. You won't be dissapointed.:cool:
/ Cordless Impact Driver #13
One of the articles I reviewed when I was in the market pointed out the weight of an 18V Lithium Ion vs a 14V Lithium Ion. They suggested going with an 18V for heavy duty use but that the 14V models were easier to handle for lighter or all around duty. The article suggested that the 14V would do the heavy stuff but the battery life would be shorter.
Based on that review, I bought a 14V Hitachi Lithium Ion, my first Hitachi tool ever. At that time, it seemed a better option than the Milwaukee or Dewalt options, my usual choices.
I can tell you that I have driven hundereds of three inch plus screws into PT lumber while building out horse stalls with zero issues. The 14V drills lighter weight was nice when I carried it in a bucket while installing fence hardware too.
Regardless, these tools are amazing to use. I do find that with the longer sizes that square or star (torx) hardware heads work better than phillips. The phillips need a little more pressure to prevent spinning out.
/ Cordless Impact Driver #14
I would be surprised if the Hitachi 14.4 volt was much lighter than the Makita 18 volt with the 1.5 amp hour battery. It is a very small and light weight tool. The Makita has the advantage if a 15 minute battery charge and 2 different sized batteries to use in the same tool. Using the 18 volt battery format opens up a lot of useful possibilities that are not available in a 14.4 volt format. Makita, DeWalt and Milwaukee have a very extensive line of tools that they have made available for the 18 volt form factor, many of them are not available in other voltages and the difference in weight of a 14.4volt battery and an 18 volt battery of similar amp hour ratings in the Lithium ion cells isn稚 much.
Having said all that, if the 14.4 Hitachi does the job and fits your hand, then that is the tool for you. They are nice tools and the any of the Lithium Ion batteries are the best.
The original poster said he already had a drill, I advised him to buy an impact driver to use his existing batteries, as I have not yet found one that didn稚 far outperform the same manufacturers drill when it comes to driving screws. Of all the ones I have I find myself grabbing the Makita with the small battery the most, but if I am going to drive a lot of screws I go for the Milwaukee and the 3.0 amp hour battery. That thing is unbelievable. It will twist off シ" bolts like they are taffey.
/ Cordless Impact Driver #15
I have a 12v dewalt and an 18v dewalt. They'll drive the same screws.
The 18v will drive more of them faster. The 12v is quite a bit lighter and
more nimble.
Get somthing to match your other cordless tools if possible. I'm up to
8-9 drills/drivers and interchangeable batteries are a nice plus.
/ Cordless Impact Driver #16
This is why I switched to McFeely's stainless steel square drive screws for fence work. :)
/ Cordless Impact Driver #17
Another vote for the DeWalt 18v. I have two for work now and just ordered a third for my other man. I am replacing a Bosch. If my guys can't tear it up, it is pretty good. They are having pretty good luck with all my DeWalt 18V. The recip saws are great also.
/ Cordless Impact Driver #18
The Makita 18V Lithium Ion works great. It always gets good reviews from the pro's as well. It has great balance.
Ken
/ Cordless Impact Driver #19
Steve C, I agree with everything that you said. I have a Milwaukee 18V nicad set that came with three batteries and it is nice to have everything compatible. I have only had the Hitachi about a year and a half but since that time, there are a lot more offerings. At the time, I had narrowed it down to either a Makita or a Hitachi. I always kind of shyed away from Hitachi. To me, they look more like athletic shoes, lol.
/ Cordless Impact Driver #20
I always kind of shyed away from Hitachi. To me, they look more like athletic shoes, lol.[/QUOTE]
:D:D:D My wife has told me that some of the Hitachi tools look like something from a science fiction movie. The looks are a little to flashy for my taste. Its to bad because they seem to work well. I see that Makita is starting down that same path with their new circular saw with the chrome accents on it. I think the guys in the design department have been smoking funny stuff during lunch.:D:D:D:D
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
GRACO KING XL45 PROTECTIVE COATING SPRAYER (A67714)
GRACO KING XL45...
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
2011 GORILLA BUILT MANIFOLD TRAILER (A67714)
2011 GORILLA BUILT...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
