Quick-connect loader fittings
/ Quick-connect loader fittings #1
DMF
Mass
Massey Ferguson 1552 Cab Model
I want a set-up where I can pull one lever and easily disconnect all 4 fittings on my loader. I'm sure someone makes such an animal... Who knows where and how much will it cost me?
/ Quick-connect loader fittings #2
Probably get better hits on this over in Hydraulics, but I'm thinking the easiest way might be to go with bulkhead fittings, where you can attach them all to a plate and push-pull the whole plate to disconnect the fittings.
-r-
That's what I want...where do I get them?
/ Quick-connect loader fittings #4
I have never seen such a device...But for what I am sure it would cost-plugging or unplugging 4 QD's just doesn't seem like a big deal.
/ Quick-connect loader fittings #5
The MF loaders on the higher HP tractors have the exact set up you want, they are made by ALO, and painted Red. Talk to your dealer.
http://www.masseyferguson.com/agco/MF/NA/Tractors/MF5400/900SrsBrochure.pdf
See the loader on the front page of the brochure. :)
If we ever do add a loader, I will be getting that QD valve. :)
/ Quick-connect loader fittings #6
Wow, that QD valve looks slick! Something like that would really make life easier.... :rolleyes:
You would think....but it is a royal PIA on my tractor. The way the fittings are mounted, you cannot slide the sleeve back on the female end. My dealer said that the fittings will push in and pull out without requiring to slide that back and he's right, but I **** near pull my shoulder out everytime I try it. They said it would get easier/looser over time...doesn't sound like a great set-up to me!
That's exactly what I want!
/ Quick-connect loader fittings #8
Great. Let me know what you find out, and pics please, if you do!! :)
My dealer said it was not available for my tractor.... :(
/ Quick-connect loader fittings #11
I have seen a single lever disconnect for multiple connections - unfortunately, i do not remember where but they are quite expensive.
Ken
/ Quick-connect loader fittings #12
G'day we have used a few differentbrands of multicouplers but have found the faster brand to be the best sorry but i don't know how to post links but i am sure you will find it with google they are not cheap though in excess of $1k (over here). Hope this helps:)
Jon
/ Quick-connect loader fittings #13
RHINO TURBO 96 SHREDDER (A65643)
RHINO TURBO 96...
Invoices (A65640)
Invoices (A65640)
Case 90XT Skidsteer Loader (A66285)
Case 90XT...
E-Z TRAIL 500 GRAIN CART (A64277)
E-Z TRAIL 500...
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
