Ballast What do 4310 wheel weights look like?
   / What do 4310 wheel weights look like? #1
mfreund
Eastern Ia
JD 4310 eHydro,
After a fruitless search through the archives, What do the wheel weights for a 4310 with r 4 tires look like? I want, not need (thanks for correcting me honey), more weight for the rear tires for loader work in the winter. I have thought of making a bracket and adding the weight to the box blade, but would like to look around. I would like to remove them in summer to run the mower. The r4 tires are such a hard rubber that when cold they are like steel wheels.
My hope is to find a set on a used tractor at a dealer or on eBay. Thanks for the help! :)
   / What do 4310 wheel weights look like? #2
I looked on Deere parts and it shows both 24" wheel sizes and 16=17" wheel sizes. Should indicate what you need to know.
   / What do 4310 wheel weights look like? #3
Hi Mfreund:
I cannot find anything to suggest wheel weights for R4 tires look any different than wheel weights for R1 or Turf Tires. However, the wheel size (diameter) does have a significant affect. The bigger wheel supports a bigger weight.
There are pictures of both wheel weight kits available for the 4310 on page 36 of this manual (PDF Format - Free Adobe PDF Reader software required).
I hope this helps.
Sidenote: The same web site has an interesting error page. I think every tractor web site should use this.
-Bill
Thank you both very much. That answers my question. I wanted to look up the part number and price it but the number is no longer valid. Well, I need a oil filter to change the oil before winter. I guess I will ask while I am there!!
   / What do 4310 wheel weights look like? #5
Hi Mfreund:
I hope this helps.
-Bill
GoodAfternoon Bill,
Is there a WEB page such as the one here for the 4520? Lot more information than was in my manual.
Thanks,
Jim
   / What do 4310 wheel weights look like? #6
Hi Jim:
Please tell me if this helps (Free PDF viewer required) at all. Unfortunately, it is not as detailed as the standard 4000 series (not TWENTY series) manual I posted for Mfreund.
-Bill
   / What do 4310 wheel weights look like? #7
Hi Jim:
-Bill
Bill.....That is exactly what I was looking for. Thank you very much....Jim
2000 Ford F-550 Altec AT35-G 35ft Bucket Truck (A53422)
2000 Ford F-550...
2008 Dodge Ram 1500 (A55973)
2008 Dodge Ram...
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
