Quick Attach Plate
/ Quick Attach Plate #1
johnnylight
Gold Member
upstate, New York
TC34DA
Looking for a Q/A plate for my NH 14LA F/E/L -- for sno-way plow conversion
Where can I find one?
I have seen a few on Ebay not sure which one to buy.
all suggestions would be appreciated
/ Quick Attach Plate #2
ATI makes good quality quick attachment plate. Any of the equipment auctions like alex lyons or petrowski's usually have q/a plates, or thru a local tractor dealer. There was a post here on TBN a while ago with dimensions to make your own. Cheers
/ Quick Attach Plate #3
I bought a couple of these and they fit well and were not disappointing but it would depend on what you were going to do with it. I made a SS quick attach by 3Point hitch adapter so that I can use my pig pole, Sub soiler and such on the FEL.
ATTACHMENT MOUNT PLATE SKIDSTEER BOBCAT SKID STEER #050 - eBay (item 170408706111 end time Nov-28-09 07:02:30 PST)
dex3361,
That's the one. (Nice price)
I'll have to find out if it will fit on my NH14LA loader.
Thanks
slicktierney,
I'll check out ATI -never thought of the auctions.
Thanks
Update: I called and order the one from ebay "KFI" SKID STEER MOUNTING PLATE
they said it's universal--I hope it fits.
/ Quick Attach Plate #6
The KFI plates are a good bargain... high quality and reasonable price.
Just a bit of advice from experience... the plate as you receive it will be flat and square... the plow mount you are welding it on might not be. I welded one onto a fork frame that I had fabricated... welded one side fine, and the bottom of the other side was touching the fork frame fine, but there was about 3/16" space between the frame and the plate at the top. I welded the bottom and then used a large clamp to pull the plate up to the frame at the top and then welded it. When I went to hook it up to my tractor, I found that my method had twisted the plate slightly and it made it hard to make the pin engage on one side. Lesson learned, leave the plate square and fill in gaps at weld points with weld, reinforcement, etc., whatever it takes. If I do another, I will probably attach the plate to the tractor side, engage the pins fully, and then tack the implement onto the plate. Remove the whole assembly and finish welding... I think this would keep it as square as possible so it lines up properly with the tractor side.
westbrooklawn,
Thanks for the advice it's very helpful.
I was planning on cutting the mount plate off the plow mount and welding it on the new plate. HF has a saw that cuts through metal --well we will see.
hopefully this thread will help members looking for Q/A plate.
the link that dex pasted has all the info:ATTACHMENT MOUNT PLATE SKIDSTEER BOBCAT SKID STEER #050 - eBay (item 170408706111 end time Nov-28-09 07:02:30 PST)
I order it direct from there phone number on the ebay page not through ebay.
I recevied a email confirmation for the order --very professional.
/ Quick Attach Plate #9
i'm planning the same project for my 7108 loader. where do i get the tractor side q/a for my loader that fits universal bob cat plates. thanks
jjcc246,
The Dealer will def have it, as far as a third party --not sure.
My friend has the same loader on his JD 990 and would like to convert to Q/A lets see what we fine and post it here.
Happy Thanksgiving to all.
/ Quick Attach Plate #11
I went to the John Deere dealer last week to ask about attachments of my older JD tractor (1980 Model 2240). The dealer told me that they don't make attachments for that tractor and FEL (Model 145) any more. I asked for information about QD attachments for a tractor approx the same size and what it would take to build a QD for my FEL. He told me that I would be better waiting until next year because JD was changing their QD in 2010 to a Skidsteer style mount.
Does anyone have any info about this?
/ Quick Attach Plate #12
Do a search on "quick attach adapter" and I think you can find one. There are several companies that make them. I looked a year or so ago,if I had saved them I would have posted the links.
/ Quick Attach Plate #14
Are they all the same functionally, or are there differences I need to be aware of?
IE: Larger and smaller sizes for different size machines, different means of attachment by brand, etc.
Also, how do I know the difference between the piece wich mounts to the FEL and the piece which you would use to build an attachment?
/ Quick Attach Plate #15
the peice that is always attached to the loader arms is the "machine side"
the peice that is always part of the attachment is the "attachment side"
they *should* be all the same, and i have yet to see one that is different. it is an industry standard on modern machines. i seem to remember loading an older gehl skid steer on my lowboy that was different, but same idea. Anything described as "universal skid steer attachment plate" is going to work.
as for size difference, the little walk-behind bobcat MT series mini track loaders use an identical, but smaller system. exact same idea, just the plate isnt as wide or tall, b/c the machine is so much smaller. they do not interchange w/ the larger machines
/ Quick Attach Plate #17
Check out my post on Craigslist Eastern CT under farm and garden for some photos of snow plow adapters I make. Use the search term"plow adapter"
I can be reached by email at rsr025@ct.metrocast.net if you have any questions.
/ Quick Attach Plate #18
Wrong side. I'm looking for the machine side to adapt onto an old JD 145 FEL.
/ Quick Attach Plate #19
Dcyrils,
I'm scouting bobcat salvage places and repair shops to find a machine side 'Quick Tac' plate I can use to make an adaptor. I've got a Bro-in-law in East Tx that works in a repair shop and he tells me he sees one every once & awhile. They seem to be difficult to come across used. I priced a new one at $450 in town.
Good luck with your search,
Rgds,
tim
/ Quick Attach Plate #20
Dcyrils,
Rgds,
tim
The first one I found was all ready to bolt on to my 2240, but they wanted almost $2K. I thought that seemed a little high and kept looking. I've found two places selling the ones you adapt to your machine yourself for $499. Thought that seemed much more reasonable.
2004 160 LC John Deere Excavator (A62613)
2004 160 LC John...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
(4) 265/65R18 TIRES & 5 LUG RIMS IN BOXES (A64278)
(4) 265/65R18...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
