Garden Tractor Dump Body
/ Garden Tractor Dump Body #1
oneparsec
Has anyone converted and and added a dump body to a garden tractor? I've got an old Roper tractor thats been sitting in the back woods for a few years, (needs to be repowered). My wife has a hard time pushing the wheel barrow after cleaning out the stalls in our barn, and I thought if I could add a dump body to the tractor, it would make it much easier for her when I'm not around to help. Any idea's or suggestions? Anyone done this before?
/ Garden Tractor Dump Body #2
Don't laugh.......but I have $23.74 in this (wood and one hydraulic fitting). It'll look better with some paint (gotta get rid of that ugly green and yeller..), and I have since made a battery box and got it wired up.
/ Garden Tractor Dump Body #3
I can't remember where I saw them, maybe on another forum, but a couple of people built some really neat ones:
Thanks for the photos and ideas, give me something to work with
/ Garden Tractor Dump Body #5
How would this work using a lawn mower as the base machine?
What is it that makes a garden tractor preferable?
Clem
/ Garden Tractor Dump Body #6
Bobodu,
Does your masterpiece have an hydraulic dump? Tell us more about it. Any more pictures? My wife needs one of these. :)
Thanks,
Clem
/ Garden Tractor Dump Body #7
That will work. I like the hood design pretty good. I'm building a dump box on a bolens hydro eliminator. I extened it 36'' and the box is 48x48. The tractor had hyd lift for the deck, so it had a valve that I'm using and I just need to add a longer cylinder positioned in the back to lift the box. I'll do my best to get pics on here when I get a camera. I'm alot better with a welder than a computer. I really enjoy the projects u guys have on here. way to go Jack
/ Garden Tractor Dump Body #8
I don't remember where, but one of the sites had a walk behind one made from a snowblower with a wheelbarrow tub mounted up front. I started building one from a rear engine rider, with a wheelbarow tub in front, but traded it for a laptop computer before it was finished.
/ Garden Tractor Dump Body #9
Does that come with pedals?
/ Garden Tractor Dump Body #10
I looked around and I don't seem to have any pictures of the pump before I covered it up with the wood. But the pump is mounted about halfway down the main frame with a belt going up to the engine. Another belt runs from that back to the tranny and this one has a movable idler pulley to engage the gears. I linked the pulley up to it only tightens the belt when the peddle is pushed. Anyone who has real meat eatin' God fearin" gears knows what a pain it is to put the tractor in neutral every time you move to a new pile. The pump is a 1.7 gpm with a built in valve and this powers a single action ram. Still have to get a big spring to pull it back down because I didn't have enough room to mount the hinge far enough back to let gravity do the job and I had this cylinder on the shelf.
/ Garden Tractor Dump Body #11
Here's another way to run a small pump. This is actually a P/S pump from a Sonoma that I won on ebay for 99 cents plus 3 dollars shipping!! There is a tank under the seat that I made from a short chuck of 5 inch pipe.
/ Garden Tractor Dump Body #12
bobodu,
Sorry for the joke. I couldn't help it.
The wooden hood is very creative! Had it been mine, since I don't weld, it would have still been uncovered with the engine exposed. Nice miters too.
/ Garden Tractor Dump Body #13
Didn't bother me a bit because I actually gave thought to adding some...
/ Garden Tractor Dump Body #14
There are a couple of examples of zero turn type tractors hooked to a integrated dump trailer. I have been on the lookout for a second lawn tractor rear end to make a 4x6 dump tractor, among many plans to move dirt. If your land is flat one of those zero turn units would work. For me, using a 1,200lb 4x4 Kubota to pull up to 1500 lbs of dirt (maybe more) and I often get stuck even with tire chains on all four wheels. I almost always need the bucket full of dirt to pull the trailer up hills. If you plan to use a garden tractor, do something like bobodu, push the driving wheels back so the weight is over them.
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2024 Keystone RV Retreat Camper, VIN # 4YDTHRT28RW260127 (A61165)
2024 Keystone RV...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2016 Big Tex 50LA Double Axle Utility Trailer (A61165)
2016 Big Tex 50LA...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63118)
2021 Unverferth...
