John Deere 318 Not Charging!
/ John Deere 318 Not Charging! #1
Scotty370
Buffalo, New York
318 John Deere, 4200 John Deere, 1947 John Deere "M"
Guys, don't kill yourselves on this one, I've got the huge service manual, that I've yet to deleve into. But just wondering if anyone knows of a 'trouble-spot' that I should be looking at first! Thanks in advance! ~Scotty
/ John Deere 318 Not Charging! #2
Loose fan belt, corroded wires at alternator or generator, blown fuse, wire broken in the system, bad cell in the battery...
That's a start (pun intended)
/ John Deere 318 Not Charging! #3
Disconnect the battery and try charging it with an plug in battery charger. If it takes a charge, you've eliminated the battery from the possibilities. If not, then you've identified the battery as the problem.
/ John Deere 318 Not Charging! #4
I've replaced the rectifier/regulator on my 318 at least twice in the past 20+ years. Suggest looking at that.
Wayne
/ John Deere 318 Not Charging! #5
If it is not charging and the obvious connections are tight/clean then it is usually the rect/reg.
I did one time, on a kohler, have a plug slip off the reg/rect. and I found this out after I bought a new one.
no matter, a few years later I needed it as the old one went bad, and they do go bad.
Kind of like a headlight, good service but in time,they burn out.
Thanks Guys! I may have a problem with the ignition switch, as it sometimes has to be 'wiggled', before starting, but I replaced it once! I didn't think that would have an effect on the charging circuit once it was running! The battery is good, and up to charge,(12.6v). Think I'll go after the Regulator, as it's never been replaced. Poor thing sits outside 24/7/365! TIA ~Scotty
/ John Deere 318 Not Charging! #7
The next thing I would check, is the voltage at the output of the regulator while it is running. If it is the same as the battery, the regulator is bad. If it is higher as it should be, the issue is in the wiring, connections, or battery cables.
/ John Deere 318 Not Charging! #8
An up to charge battery should be over 13 volts. Above 13.8 volts, you start to get electrolysis. Above 14.5, it really starts to boil off the water. While that _should_ be independent from the regulator, the regulator will be running wide open trying to charge that battery so if it's marginal the regulator might be unhappy.
Just more data for you, dcyrilc debug path is still the one to follow. BTW, my 318 is 19 years old and on it's original regulator.
Pete
/ John Deere 318 Not Charging! #9
If you are wiggling the switch, bet ya a dollar to a donut,you have a connection problem not a regulator problem.
When you pull off the connector@ the back to the switch, remove the wires from the connector and check to see if they are tight on the switch spades.
Do this one @ a time so as to make it non confusing.
I have seen where they have been arcing,because of poor connection causing the plastic connector to melt.
You might have to change 1 or 2 connectors, if they are really bad and have lost their springiness. ( avail @ auto stores old style G.M.)
also check the switch spades or treiminals for corrosion/rust if it sets outside.
Just thought I'd give an update, and thanks for your input! I replaced the switch. I looked up the part numbers on JD, then Google for 'crosses'! (Yeah, I'm 'thrifty') Switch from JD- $19-, switch from local small engine guy- $12.99. That solved the 'wiggle-thing'! Pulled the two outside regulator leads and have 32VAC at medium idle. They call for 26-52VAC at high idle, so I'm in the range! re-plugged them, and pulled the center lead on the Reg, and got no DC output! Looks like the regulator!! Called JD for Reg price, $81-!!! Checked Google for a 'cross' that led me to EBay. and ordered an exact replacement for $31-!! More to follow! Thanks Again! ~Scotty
/ John Deere 318 Not Charging! #11
Glad to be of help. Keep us posted and let us know if the regulator fixes the problem.
/ John Deere 318 Not Charging! #12
Scotty,
There is a difference between cheap and thrifty:
A thrifty person saves a dollar here or there, so he can spend it on something else, like beer
A cheap person saves all his money and drinks his friends beer :D
Final update: Replaced the Rectifier/Regulator. Plugged in the Stator wires, and again 30-40 VAC! With the center lead disconnected I read no DC volts when tested to ground! I had 12vdc from the lead that plugs on to that center terminal, but knew I was just reading battery voltage! Thought I had a bad part! Plugged it in anyway, and viola!! Battery light goes out, and I've got 14VAC from the (connected) center terminal to ground!!! Guess I had to have a 'draw' on it, before it 'kicked in'!! Some things electrical, I just figure, "It's Magic" and move on! Looks like I'm good to go!!! Thanks again!! ~Scotty
/ John Deere 318 Not Charging! #14
Scotty: Congrats! See my first post to you question also.
regards
Wayne
/ John Deere 318 Not Charging! #15
Glad to hear your running again! It's alway good to hear when the problem has been solved.
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Copper Eagle Weathervane (A65583)
Copper Eagle...
6ft Teakwood Cowboy (A65583)
6ft Teakwood...
2014 FREIGHTLINER CASCADIA (A65643)
2014 FREIGHTLINER...
Land Pride 3-Pt Rotary Mower (A66408)
Land Pride 3-Pt...
