2660 on a hill
/ 2660 on a hill #1
AHNC
Gold Member
Nevada City CA
Kubota BX 2660 & BX-23
How do you safely get a tractor up and down a hill that has some grade to it. It is a pretty consistent slope. I'm thinking of mounting the BrushBull and backing down and tying off the front to a large walnut tree and winching up and down to assist the 4wd. I'd be going straight up and down the fall line. No cross slope. I think with a bit of weight in the bucket, held low, it should be okay. We did this with a D9 on some very steep slopes on pipelines, so I'm thinking it should work ok here. Then again, I wasn't running the 9;)
Suggestions gratefully received
/ 2660 on a hill #2
I thought/think I have fairly steep hills and I've never done anything other than keep the bucket low if FEL is on, always keep it in low 4wd and go slow. Forward up and forward down. If I was concerned about the steepness of going up I would back uphill, never back downhill but I've never had to resort to that. I will take this opportunity to warn new and old that wet grass on a hill can be like ice. I did it one time down a hill and it was just hold on and try to keep the wheels straight till I got to the bottom.
/ 2660 on a hill #3
Like JohnThomas, I routinely go up and down some pretty steep inclines without any problems. I do it with and without my FEL; always in 4WD low range. I rarely use my rear diff lock. It is amazing how well the BX series handles slopes.
I have rear wheel weights, but none in the front; never need them.
/ 2660 on a hill #4
I don't know about backing down, I think I want to see what is coming without haveing to turn around in the seat all the time. I think the most important thing is to stay in low gear, low speed, FEL low but not so low as to catch on anything and flip you so be mindful of FEL height at all times, keep your foot off the clutch if you have one and stay in gear and remember slow...slow and slow. You mention going straight up and down the fall line and no cross slope. I might suggest a slight zig zag steering on the way down..but I do not know the degree of your slope and no picture so this is all with out that info. Be careful
/ 2660 on a hill #5
Can you measure the steepness of the hill?
Two levels can be used to measure the amount of rise over distance. Place one level vertical and the other level running horizontally from the first level to the ground.
/ 2660 on a hill #6
There is probably a formula to convert "pitch" to degree; would be interested to know what it is.
/ 2660 on a hill #7
I threw some cinderblocks into my FEL to give it some weight several months back when mowing a hill. Upon thinking about it, probably not the smartest thing I've ever done. Had the tractor went front over tail in a flip, the unsecured cinder blocks would have come right at me.
I did feel though that having the FEL loaded up helped. I'd just recommend that the load be secured to the FEL, just in case.
/ 2660 on a hill #8
FYI,
It's the arctan(rise/run) answer given will be radians or degrees depending on the calculator setting.
for example the arctan(1/1) = 45deg and the arctan(0/1) = 0deg
Slopes are usually given in percent grade which is a percentage of 45deg
A 100percent grade is 45deg a 50% grade is 22.5 deg a 10% grade is 4.5deg etc....
If you don't have a calculator that can determine the arctan(rise/run) then look at this tangent table and look up the closest corresponding number on the tangent column and look at the degree column.
/ 2660 on a hill #9
FYI,
ZOOM: The sound of that going over my head. All I know is roof pitch such as in an 8-12 pitch.
At my age, I have developed a pretty good feel for the two most important descriptions on slopes: Steep and too **** steep.
/ 2660 on a hill #10
LOL.
Get a 3' bubble stick level. Hold it level with one end on the ground. Measure the height of the other end. Use arctan (height/36) for angle or divide by 3 for pitch (in 12ths).
If this happens, it was too steep: YouTube - Explain This To Your Insurance Company LOL
/ 2660 on a hill #11
/ 2660 on a hill #12
I rather not back down a hill. Too much of a chance to slide sideways and roll over. Going forward makes me feel safer, with no implements in the rear.
/ 2660 on a hill #14
Well you asked. Actually the way I always measure a grade is by the ol' pucker factor. Works every time.
/ 2660 on a hill #15
Yep, that's what seems to work best for me. I operate four different tractors in addition to a 700 Grizzly and Rhino on my properties and each will handle slopes differently, so I just go by feel and experience and haven't turned anything over yet. I have been operating machinery for over fifty years, but occasionally the old alarm bells tell me I may be right on the edge though; pays to be careful.
/ 2660 on a hill #16
This is the one I hate or the one where I think "I believe I may have gone past the edge on this one"!!!!
/ 2660 on a hill #17
This one brought a smile to my lips ! :D Oh boy, I can relate. However these hard lessons sure teach us how to be safe in the future pretty quick doesn't it ?;)
/ 2660 on a hill
This is like learning to fly. They tell you that takeoffs are optional. Landings are not. When I do it, I'll take care!;)
