jmc
Elite Member
- Joined
- Jul 21, 2003
- Messages
- 3,224
- Location
- SW Indiana
- Tractor
- Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Hello,
I volunteered the TBN brain trust to help a friend disassemble his (imported) 5 ton hydraulic press cylinder, picture attached. It's a single acting cylinder with an internal spring return. The picture shows the cylinder with the end completely unscrewed, and a pair of shims holding the rod out against the internal spring pressure. Obviously there could be a lot of different designs for these things but based on what you've seen in the past:
Question 1- Is the stop collar (sitting on top of the shims) assembled to the rod with a press fit or is it threaded?
Question 2- Is the return spring a compression spring on the rod side of the piston or a tension spring on the pressurized side of the piston?
Question 3- Will this be difficult to reassemble because of the spring tension?
Thanks,
John
Thanks,
John
