L3000DT turns over, won't start
   / L3000DT turns over, won't start #13
I would check the fuel shut off solenoid. Both of my Kubota tractors energize the solenoid when they shut down, and about 4 seconds after shut down you will hear it time out and click. It may be stuck shut. They don't energize the solenoid to open they energize the solenoid to close it(stop fuel).
My tractor works perfectly. It wouldn't start because, incredibly, I had failed to push in the pull-stop knob. Something I had done every time, of course, I had ever started it, including many times that very day. When I started it last night, it started instantly and I got the distinct sense it was muttering under it's breath about me.
I'm going to make a big "PUSH TO START" sign, I guess.
Thanks again to everyone for all your help. Sorry for the snipe hunt!
   / L3000DT turns over, won't start #15
Glad you found the problem, it's usually something simple, at least we all hope it is !
I remember years ago I was out dirt biking and managed to clip a tree with a handlebar. If you've ever done that, you know what happens, if you haven't, it promptly spits you off the bike, usually sideways.
After dusting myself off and checking for broken things, like bones, I picked the bike up and tried to restart it. No go. After maybe 10 minutes of kicking it over and swearing at things in general, I stopped to rest my leg.
Mused over what could be wrong, like flooded engine, ignition problems after the crash, etc. Noticed that the kill swith on the handlebar was in the "OFF" position. Sheepishly turned it back on, kicked it once more for good measure, and rode away.
Chilly
   / L3000DT turns over, won't start #16
My manual shutdown has a return spring. Does yours not have one or perhaps it is binding somewhere?
   / L3000DT turns over, won't start #17
Hey Dirk - don't sweat it. That's what I meant by the kill switch and the reason I knew to check that is because I did the same thing once long ago. Went through all kinds of trouble shooting before I found it! Definitely always start with the simple stuff!
   / L3000DT turns over, won't start #18
I also have done this-makes one feel a bit humble though. betcha you won't forget again-until maybe in a couple weeks and you're in a hurry.
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2017 Peterbilt 567 Tri-Axle Dump Truck (A49461)
2017 Peterbilt 567...
1240 (A50490)
1240 (A50490)
