3000 Loaders
/ 3000 Loaders #1
evan4434
Iowa
Cub Cadet 3184
Lets talk loaders.
I am looking for a loader for my 3184.
Here are my options so far.
Looks to be the strongest one of the bunch, and has its own pump. $2,500 ouch!
http://www.kwmanufacturing.com/asst/pdf/cc_general.pdf
Uses Cubs hydros does not have a sub frame. $1899
New Page 1
Looks pretty weak, but I am waiting to get some photos and details on the new design. $1,400 - $1,700.
https://www.kellyproductsinc.com/front_end_loader_info.html
Does anyone know of any other brand? Not a Johnny bucket either I need this to be able to lift a lot higher then a Johnny bucket.
Which one do you think is the best?
/ 3000 Loaders #2
just from what i can see you have them listed best to worst. the bottom one is probably a decent product, but looks pretty flimsy. you would have to ask them for blueprints to see whats the best and strongest.
/ 3000 Loaders #3
Evan -
I might have mentioned this before, but I had a KW loader on a Cub 1782, and it worked great. Like the separate pump setup. Strong little loader. Downside - had to take the deck off to mount the subframe...and took some time to install subframe and loader. But, overall very happy with it. Good luck, let us know which option you choose.
/ 3000 Loaders
Evan -
Ya I see the subframe as a pain as well. I would like to leave my deck on. It does look like the strongest design though. I think I would get the groundhog loader if they could give me some more information on it. I have emailed them 3 times with no response. Then I finally called them and the guy knew almost nothing about it. He said the guy that knew all about them had quit and he would get back to me, and that they have only sold 7 of them. Well that was about one month ago now. With the groundhog loader you can also get a lot of different attachments like a 60" snow blade, auger, and forks.
/ 3000 Loaders #5
it would probably cost you just as much to have one made by a local welding shop. give a fabrication shop a set of blueprints and they should be able to come up with something or they should be able to adapt something to fit with minimal modification.
/ 3000 Loaders #6
While I can see the alure of putting a loader on your 3000 series... I can't say I think it's a good idea. I can't imagine you'd be able to truely lift all that much. I'm not sure what these companies are claiming for lift capacity, but I know most sub compacts have anywhere from 500-700lbs. My sc2400 specs out at 700lbs at the pins. Keep in mind, it also weights over twice as much as a 3000 series tractor. A 3000 series tractor weighs in at around 1000 lbs depending on deck size. I don't think it would do well with 500 lbs 3 feet out ahead of the nose. I don't know, I just don't see it being all that helpful for the price.
If you're dead set on getting one, here is my take. Option one is def the best looking of the three, but it's also the most expensive. It probably gives you the best chance of actually being able to use the bucket effectively. Option two looks like a good compromise. You don't need the sub frame and it still looks to be a quality product. I'd imagine load capacity would suffer due to no sub frame and overall just being less heavy duty. Option three is one step above the johnny bucket (which, is pretty sorry IMO). Honestly, if you just want to move around some leaves and mulch, option three is your best bet. I'm sure it'll have no issues lifting all of 100lbs. If option three looks good to you, you'd be miles ahead to build it yourself. I'm sure you can do it cheaper and probably better at the same time.
Also keep in mind most of these frames were never designed to handle the stress of a FEL. These tractors were designed to cut your grass, pull super small implements, and maybe push some snow/dirt.
Also, something to think about. For the price of the first one (2500), you could probably find a decent used tractor with a FEL and it would actually be designed to do what you want. Just a thought.
Good luck.
/ 3000 Loaders
I think you are right. I am leaning towards option 2. Another route is to sell mine and get a mower that already has a loader on it. I have see a few on ebay for around $2,500.
How much do you think a 2001 3184 with a 3 point hitch and only 150 hours is worth? I would love to sell mine for $2,500, but is it worth that much?
/ 3000 Loaders #8
I think with the right buyer, you could get that. I found one on tractor house for 2650.
2001 CUB CADET 3184 Riding Lawn Mowers For Sale At TractorHouse.com
That one isn't in the best shape if you look close. So, if yours is, I'd think 2500 would be a fair price for someone looking to buy at 3000 series tractor.
A quick search on tractor house for cub cadet brand tractors with loaders for under 2500 didn't get me any results. However, if you were to put the 2500 you get for your tractor with the 2500 you could have spent on a loader, you surely could get something.
/ 3000 Loaders
Mine is in about the same shape as that one, but I have a $1,000 3 point hitch on as well. I should be able to get $2,500. I think I will put it on craigslist this spring for $2,995 obo. Between what I can sell mine for and what I would have spent I should have around $5,000 or so. That should be enough to get something. I really want a SC2400, but I don't have $12,400 for one.
/ 3000 Loaders #10
I recently sold a 2006 Cub 5254 4X4 sub-compact with loader and low hours for 5700.....so they're out there.
/ 3000 Loaders
I found a groundhod loader for $950 off an atv with a lift height of 60". It looks like all I need to get is the bottom of the feet for the cub version and the stabilizers to the front of the mower to the loader. The best part is it comes with its own hydro system and controls which is 12v and stays mounted to the loader. I will be posting photo's after everything is installed in the next two or three weeks.
/ 3000 Loaders #12
Wow...
that's quite a score! Looking forward to pics.....
/ 3000 Loaders #13
i cant wait to seethe pix of this-im waiting for my gt3200 to come in & i was cinsidering getting a johnnybucket-this sounds better,scott
/ 3000 Loaders
Here is the loader that I am getting.
Note I am buying the atv loader version and just simply putting the Cub Cadet feet and front stabilizers on it. You can get this at Concord equipment. This way I don't have to tie into my Cubs Hydros. It was going to cost me about $600 to get two more hydro circuits on my fender and that is just the part cost. Plus this 12v is stronger then our Cubs Hydros anyways.
This is a heck of a deal because they run about $2,400 new for this model as it is the 60" lift height version.
The best part is I can take this off my cub and put it on my friends four wheeler anytime.
Attached is the loader that I am getting. As you can see it is all self contained and everything stays with the loader when it is off the mower.
Here is there website.
Grounhog Loader System
/ 3000 Loaders #15
evan4434-can the loader stay on with mower deck? thank you for the pix-it looks like a great unit hope it works out for you,scott
/ 3000 Loaders
Yes it can
/ 3000 Loaders
Well we got it mounted and man this is a nice addition to have. We had to fabricate the front mounts to the loader out of 1/2" x 1" steel. The O ring seals on the the pump reservoir are leaking a little and I will have to install some new ones. It is just to darn cold to do it now. Other then that this thing works great. I lifted 400 lbs with it no problem. I will post some photo's once it warms up and I can get this thing cleaned off a little. The only thing that I don't like is the loader pump is mounted about 3" away from my hood, so I cannot open my hood all the ways. Luckily the Cub 3000 has removable side panels, so I can get to most everything under the hood. The other option is to remove the loader which is not too bad either.
/ 3000 Loaders #18
Sounds interesting! Glad you got it hooked up. Looking forward to some pics....400 LBs is pretty good lift.
/ 3000 Loaders
Here are some links with my 3 point and loader. I also have it for sale on ebay right now. I found a good deal on a Sub Compact and need to sell mine to get it. Just after I got my loader on! If it does not sell I am pretty happy with is anyways, so it is no big deal.
It was -13 F when I made these videos, and the loader sill worked great.
CUB CADET 3184 MOWER W/ FRONT END LOADER 3 POINT HITCH - eBay (item 130357869862 end time Jan-16-10 14:16:49 PST)
Youtube video links
3 point
YouTube - Cub Cadet 3184 Fork Lift
YouTube - Cub Cadet 3184 3 point with Iron man Manufacturing blade
Loader
YouTube - Cub Cadet 3184 with groundhog loader part 1
YouTube - Cub Cadet 3184 Groundhog Loader video part 2
/ 3000 Loaders #20
Very nice setup!
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
Black Walnut Lumber (A61166)
Black Walnut...
2023 Titan Trailers 48ft. T/A Walking Floor Trailer (A61568)
2023 Titan...
UNUSED MINI EXCAVATOR WOOD GRABBER (A62130)
UNUSED MINI...
New/Unused Receiver Hitch (A61166)
New/Unused...
2021 CATERPILLAR 299D3 SKID STEER (A62129)
2021 CATERPILLAR...
