2 bottom plow
/ 2 bottom plow #1
duck
Ottertail
CT230
I will finally be getting my CT230 next week. I am one of the few getting the ag tires. Has anybody tried to use a 2 bottom plow on these? 3-pt or other? :rolleyes:
/ 2 bottom plow #2
Welcome to the forum.
I'd venture to say it should handle a 3pt 2 bottom plow, but doubt a pull-type 2 bottom.
Said to handle a 78" cultivator on the 3pt, but I'd not expect too much from the plow, as I wonder if you have draft control on the 3pt. That would be important for a 2 bottom plow to work very well. IMO.
/ 2 bottom plow #3
It will surly handle a two bottom plow. Now tractors weight, and getting traction to pull tat plow are being the biggest issue. In average conditions, a 12" plow requires about 10 hp per bottom. Keep that moldboard clean free of rust, do not just plow and park it out side when done. Oil it down cover it up. Have you plowed before? A improperly adjusted plow, or people taking to much out in one furrow, can be really tough on a machine. A plow is one of man kinds greatest inventions. I plow my gardens 2x a year. What type of plow did you go with?
/ 2 bottom plow #4
They have position control as draft control would not really be need or used on a cut imo.
/ 2 bottom plow
I have an old 1 bottom trip type. It works fine but I'd rather have a 2 bottom and get er done quicker if it will handle it.
/ 2 bottom plow #6
What exactly is draft control vs. position control:eek:
/ 2 bottom plow #8
Thanx articatsopro for that link--I think I got now:confused:. Non- position control would be like your front end loader valve function. Position control would be like a normal 3pt lever control valve function. And draft control would be like position control with auto load sensing gizmos and auto actuators. When I refer to normal 3pt lever, I'm referring to the one on my CT335
/ 2 bottom plow #9
Hey Duck
Do you have fluid in the tires? This will help too, but not necssary. I had them put in Rimguard and I have R4's. Pulls like a dream!:D
/ 2 bottom plow #10
I have an old set of Ford 2 blade bottom plows, its a 3pt hookup and have plowed very well so far with my 230. I limited the depth with the top link so I don't dig too deep and take two runs at the field.
AS soon as i can get a deal on a tiller...them plows are out of here.
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
2016 PETERBILT 579 4X2 S/A DAY CAB TRUCK TRACTOR (A59908)
2016 PETERBILT 579...
