No gear, no go.
/ No gear, no go. #1
Charlie Horse
Lipan, TX
MF 281 74hp 2wd
All of a sudden I can't get into gear, I have checked the hydraulic fluid, adjusted the clutch lever (because there was just no pedal), nothing works. I fear that I may need to replace the clutch, but I am not well versed in double clutch assemblies. If it is the clutch, do I change both, or just the one that needs to be changed? This is a job that I have to do myself, can't afford shop rates...any one interested on telling this idiot what to do?
/ No gear, no go. #2
I think you have a better chance of getting help if you at least mention the make and model of tractor.
Better yet if you post in the particular brand name's forum.
"just no pedal" and your mention of double clutch systems suggests to me that it is more likely a linkage and control problem than a clutch wear issue.
Do you have power to the PTO ?
On a dual (or 2 stage) clutch system the PTO engages before the main transmission clutch engages to move the tractor forwards/backwards.
If there is no PTO power my bet would be control linkage, if you have pto power there could be an adjustment problem or main clutch wear (or burn).
If/when it comes down to it.... replacing both the PTO and main clutch would depend on your usage, e.g. if you have only ever used this tractor for non-PTO work then it probably wouldn't make much sense to replace the PTO clutch.
Level of difficulty to do the work ?
Depends on your skills and tools, but do know ahead of time that a main clutch job requires splitting the tractor. You will at least need enough flat smooth hard floor space and some form of rolling jacks or dollies to be able to roll one half away from the other. Plus a decent mechanic's tool set, socket wrenches, etc.
So; make, model, hours and usage would be useful info to help us to help you (-:
/ No gear, no go. #3
Can you shift gears with the tractor turned off? Or are you talking about grinding gears? Do you have a shop to work in? If clutch needs replacing you're probably looking at splitting the tractor. Lots of heavy metal to move around.
2025 Swict 60in. Bucket Skid Steer Attachment (A61567)
2025 Swict 60in...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2022 CATERPILLAR 289D3 SKID STEER (A62129)
2022 CATERPILLAR...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2003 Ford F-150...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
