adding a 3rd function valve to a 755 john deere HELP!
/ adding a 3rd function valve to a 755 john deere HELP! #21
Found this in owners manual- hydraulic 5.6 gpm , working pressure 2050psi
Excellent, any of the valve I linked will work great.
The parts from this kit should all be available from Deere if i wanted it to look factory ? Otherwise the diverter plug two 90s, two hoses, then i need the valve , and Q disconnects thats it ! Did i miss anything?
/ adding a 3rd function valve to a 755 john deere HELP! #23
The "factory" kit will NOT get you a valve to control your dump trailer-you will still have to add that. The kit is for powering a backhoe or logsplitter with it's own valve.
Right i understand that , do have any idea what ports to tap into? would they be the ones on top of the loader valve ??? and what are you suggesting i register for with JD parts , unless my dealer did it ? ( I doubt it ) AGAIN I OWE YOU BIGTIME ! , YOU JUST SAVED ME A BUNCH OF WASTED $$$:D
/ adding a 3rd function valve to a 755 john deere HELP! #25
I do not know specifically where the ports are-that is why I suggested finding a FSM. But they are probably on top of the loader valve...Maybe your dealer will copy some pages for you?
EDIT: I just looked it up-and you can get the technical manual on CD for only $55.00. Look HERE.
www.jdparts.com is a parts lookup system that is FREE to register at, it is the same basic system your dealer uses at the parts counter! Once you learn how to use it-it will be invaluable as you work on your own machine. You can even order parts online and have them shipped to your dealer for pickup. That is where I got the diagram's I posted from. Try it-You will like it. Just "think like a parts guy";)
Thank you again !, For spending your free time to educate the rest of us ! I spoke the dealer again, This time i got the parts manager and ordered what i needed and gave them an education too! Spent some time looking at the valve under the seat and have spoted the ports , looks like the seat has to come off
P.S. im all set up with that parts website, Thanks again!
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
213089 (A64276)
213089 (A64276)
2025 Auger Drill Bit Skid Steer Attachment (A61572)
2025 Auger Drill...
Informational Lot - Shipping (A63688)
Informational Lot...
2016 Nissan NV2500 Cargo Van (A61573)
2016 Nissan NV2500...
