adding a 3rd function valve to a 755 john deere HELP!
/ adding a 3rd function valve to a 755 john deere HELP! #21
Found this in owners manual- hydraulic 5.6 gpm , working pressure 2050psi
Excellent, any of the valve I linked will work great.
The parts from this kit should all be available from Deere if i wanted it to look factory ? Otherwise the diverter plug two 90s, two hoses, then i need the valve , and Q disconnects thats it ! Did i miss anything?
/ adding a 3rd function valve to a 755 john deere HELP! #23
The "factory" kit will NOT get you a valve to control your dump trailer-you will still have to add that. The kit is for powering a backhoe or logsplitter with it's own valve.
Right i understand that , do have any idea what ports to tap into? would they be the ones on top of the loader valve ??? and what are you suggesting i register for with JD parts , unless my dealer did it ? ( I doubt it ) AGAIN I OWE YOU BIGTIME ! , YOU JUST SAVED ME A BUNCH OF WASTED $$$:D
/ adding a 3rd function valve to a 755 john deere HELP! #25
I do not know specifically where the ports are-that is why I suggested finding a FSM. But they are probably on top of the loader valve...Maybe your dealer will copy some pages for you?
EDIT: I just looked it up-and you can get the technical manual on CD for only $55.00. Look HERE.
www.jdparts.com is a parts lookup system that is FREE to register at, it is the same basic system your dealer uses at the parts counter! Once you learn how to use it-it will be invaluable as you work on your own machine. You can even order parts online and have them shipped to your dealer for pickup. That is where I got the diagram's I posted from. Try it-You will like it. Just "think like a parts guy";)
Thank you again !, For spending your free time to educate the rest of us ! I spoke the dealer again, This time i got the parts manager and ordered what i needed and gave them an education too! Spent some time looking at the valve under the seat and have spoted the ports , looks like the seat has to come off
P.S. im all set up with that parts website, Thanks again!
2022 John Deere 5100E (A64126)
2022 John Deere...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
