Wish us luck ...
/ Wish us luck ... #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
My Grandson and I have started the process of getting to the rear seal of the engine on the Long 460. We have the shop manual and are following the directions. I am not a mechanic ... he's 12 years old and may become the foreman of this project ....
/ Wish us luck ... #2
Take your time and watch what went where and take notes if needed. I am sure yall can get.
/ Wish us luck ... #3
Good luck. And I think it is great that your grandson is there to learn and help you out. One thing that I recommend is taking lots of pictures in case you forget where something goes.
/ Wish us luck ...
Thanks for the advise, heres where we are with hopes to split it over the weekend ...
/ Wish us luck ... #5
dont forget to wedge the front axle with somthing so you disable the pivot action between the axle and the tractor. you probably already know this ,but you dealing with a lot of mass so slow and easy.lots of luck
/ Wish us luck ...
I have read that in the book .... however being the first time, should you care to elaborate, It would be WELCOMED advise ...
/ Wish us luck ... #7
since the tractor pivots at the middle of the front axle if you dont wedge it from both sides, when you splt the tractor if one side of the front end is heavier than the other, it might lean towards you and possibly fall off your jack stands. It seems like( or you would assume) that you are supporting front half at 3 points left tire, right tire, and jackstand where you just unbolted the rear half. but in reality you are ballanced on two points, the jackstand and the front pivot. did I explain that in a way that makes sense?
/ Wish us luck ...
Yes Sir ... you sure did, thank you. AND everyone feel free to keep the advise coming!!
/ Wish us luck ... #9
LOL enjoy working with your grandson, most of my best memories of my grandfather have grease, sweat, a few new cuss words and my first tastes of beer in them. If you have the patience he did, it will be a great experience. any Idea how much the tractor weighs? I am wondering what the best way to support the halves would be?
/ Wish us luck ... #10
When I have to disassemble or disconnect some complicated stuff in ex on car engine I put a video camera on a tripod and take a movie of the process. Then if in doubt when putting the staff back together I look in the movie how it was taken appart.
/ Wish us luck ... #11
Even close up digital pictures will help on big reassemblies
/ Wish us luck ...
Thanks Fireman. I too have great memories of working with my granddad, he was a carpenter, farmer. And a very patient man...as I am finding myself to be. My grandson was just coming out on weekends, then he got in some trouble at school and he has moved in here, enrolled in a new school. Daily chores, responsibility and a schedule ...when time permits we work on the tractor, his favorite. We also have "barn talk" !! He has been cautioned that it must stay at the barn ... G'ma may frown on barn talk in the house.
I'm not sure of the weight, I need to tractordata it ... here are my plans for the support. Besides the shims, wedges and jack stands, I have it parked directly under the steel I beam rafter of the shed, 12" beam on a 40x60 bolt together steel framed building. I plan to support the front with the jack stands as well as a chain and come along to the I-Beam. The rear with a floor jack. I think all will be well.
BTW ...when the bolts come out do they usually split fairly easy??
/ Wish us luck ...
Yes we have been taking alot of picture's and I have him drawing diagrams and reading the shop manual ... Thats redneck homework!!!!!
/ Wish us luck ... #14
I don't know on your brand/ model if there are dowel pins aligning everything together, to be safe you want to try and take the halves straight apart with out twisting too much. "Barn Talk" I like that one. what happens in the barn stays in the barn!! Good luck !! I will be interested to check back in on this thread, I am on vacation next week so it should be farther along if not complete by the time I get back to a computer.
/ Wish us luck ...
I was amazed at how easy it seperated ... Bet it don't go back that easy!!
/ Wish us luck ... #16
That looks like quite a bit of wear on the pressure plate release fingers, you might want to look at the throwout bearing to make sure it isn't wiped out. If you have to replace the part, now is the time to do it.
Enjoy your project and male bonding. :D
/ Wish us luck ... #17
+1 - I usually take digital images of the components as I disassemble, especially screws!
/ Wish us luck ...
Thanks for the advise ... I'll take a close look at that. Its amazing how much I am learning ... first time for myself and a first for the boy ... I never new he could talk so much!!!
/ Wish us luck ... #19
Wonderful project,...and such a beautiful opportunity for both parties,.....AND,...you get the tractor fixed to boot!!
(Barn-Talk "rules",....fantastic!)
My very best to all concerned,..including G'ma !!
CHEERS!
. . tug
/ Wish us luck ... #20
That wear might be normal but still check it.
Look at the fingers there are 2 sets of 3 that would make me think it is a 2 stage clutch?
tom
2024 SILVERBACK 53XH3A 53FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2022 PETERBILT 579 DUMP TRUCK (A62130)
2022 PETERBILT 579...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
2009 Ford Escape SUV (A61569)
2009 Ford Escape...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
Dingo Ditch Bucket Skid Steer Attachment (A61567)
Dingo Ditch Bucket...
