Purchasing advice/feedback on a used 2520...
   / Purchasing advice/feedback on a used 2520... #1
Ed G
Northeast PA
(Soon to be) 2520, 200cx, 46 BH, 727A ZTM, Gator, LX279
(This is re-posted from the general forum....sorry - still learning the rules!)
As a new member to this forum this is my very first post....I want to say up front thank you all for the info here - it has been very helpful; and I also want to apologize in advance for what is a long first post, as well as for what may be "rookie" questions!
I just sold my JD 790 w/#70FEL and #7BH (I was very pleased with the 790, but I need to get a tractor with a hydro trans to accommodate some recent family handicap issues). I need the tractor for general work/landscaping around my farm and house, plowing snow, and maintaining the property. I already have a Gator and a 727 for mowing, so I will not really need to mow with the new tractor. My wife and father-in-law (who is somewhat handicapped and also owns a JD 4200 w/FEL and BH) will also drive this.
I have two separate used tractors I am looking at:
#1 - Used 2006 2520 w/77hrs, 200x FEL and 46BH for $16,500...this is my first choice b/c it has a backhoe and lower hours (I did confirm through JD that the tractor is free & clear financially)
#2 - Used 2005 4310 w/298 hrs, 430FEL and 60" mower deck for $16,500....this may be a bit larger than I really need (my neighbor has one), and I would need to purchase a backhoe (I would sell the 60" mower deck).
I would like any feedback/reccomendations you all may have...some of my questions/concerns are:
- How will the FEL and BH power of the 2520 compare to the 790 I have now? Based on the specs I have reviewed is should be MORE powerful...
- How will the 2520 compare to the overall power of the 4200 my FIL has now?
- Have there been any significant design changes in the 2520 since 2006 (e.g., rear wheel spacing)?
- Is the power of the 200x the same as the 200cx FEL (I do understand the 200x is not the quick-tatch).
- Any guesses as to how much a backhoe would be for a 4310 (installed)?
- Any guesses as to how much $$ I could get for a used 60" mower deck?
Any guidance or recommendations you can add??
   / Purchasing advice/feedback on a used 2520... #2
From what you say I think I would go with the 2520, it sounds like it's more along the lines of what you need and that the 4310 is more of a "keeping up with the Jones's" option.
-The FEL and BH of the 2520 will be more powerful, but not in a "huge difference" kind of way.
-The 2520 will be very similar to the 4200, with probably the only noticeable difference being the design changes. As far as power, it's very close.
-The only thing that comes to mind would be to check to see if it has the newer designed 3-pt arms, I know there's an issue with those rubbing the rear tires. Other than that it should be exactly the same.
-No, the specs on JD's site are the same for both loaders.
-The 485 BH for the 4310 lists for $9420 on JD Builder. You could always look for a used one, but you'll still end up spending more money.
-I wouldn't expect to get much for the mower, maybe $1000 - $1500, but that could be generous depending on the condition of the mower. I wouldn't expect to sell it easily either because when most people buy tractors or mowers there looking for the 2 to already be mated together, or they've bought them together to begin with.
:cool:
Thanks WH401!! Much appreciated!!
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
