3-Point Hitch 2305 or similar sized and the northern tool 3pt 13 ton log splitter
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #1
fdmars
Gold Member
Central CT
John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
thinking of getting the northern tool 13 ton logsplitter for a jd 2305 and a jd 4115, has anyone had any experience or comments on this set up?
Thanks Fred
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #2
It will work, but will be very slow. The 4115 only has a 5.1 GPM pump, and the 2305 only 2.9 GPM is available to the implements.
thanks for the info Ken, do they make a kit to divert flow from the steering to the implements? or is 2.9 GPM all you get period.
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #4
Nope, 2.9 is it...and that will be at around the rated PTO RPM.
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #5
I just got a 13 ton log splitter. I have a JD 3520 that gives 8 gpm for implements. I cannot say it's very fast, but that depends entirely on engine rpms. I run it just above idle and barely have time to collect the split pieces while the ram is going up. Then I must put a new piece of wood under the splitter. So IMHO speed is not really important if you are working by yourself.
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #6
Fred...shoulda mentioned earlier: Look HERE for a calculator-just plug in your numbers and you can make a decision.
Thanks for the info. I will look at it
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #8
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #9
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #10
Splitting wood alone sucks.
I make sure I have a helper, otherwise its just not safe when splitting big pieces, because I split on a horizontal splitter, and the heavy pieces fall on your feet and legs, and then you have to pick them up again. I hate the vertical position, because my back can't handle that for very long at all. The lifting off the ground is horrible for anyones back.
2014 Lamar Trailers 45ft T/A Pipe Handling Trailer (A55973)
2014 Lamar...
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
2020 Tiger Turf Mower, Model 3TT11-61V-37BV-EF1, S/N R1000298, Asset# 60 (DOES NOT RUN - NEEDS (A59076)
2020 Tiger Turf...
207010 (A55853)
207010 (A55853)
HARD TOP FOR CONVERTABLE CAR (A58374)
HARD TOP FOR...
