3-Point Hitch 2305 or similar sized and the northern tool 3pt 13 ton log splitter
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #1
fdmars
Gold Member
Central CT
John Deere 2305 w/ Femco folding ROPS & Power Beyond Kit
thinking of getting the northern tool 13 ton logsplitter for a jd 2305 and a jd 4115, has anyone had any experience or comments on this set up?
Thanks Fred
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #2
It will work, but will be very slow. The 4115 only has a 5.1 GPM pump, and the 2305 only 2.9 GPM is available to the implements.
thanks for the info Ken, do they make a kit to divert flow from the steering to the implements? or is 2.9 GPM all you get period.
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #4
Nope, 2.9 is it...and that will be at around the rated PTO RPM.
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #5
I just got a 13 ton log splitter. I have a JD 3520 that gives 8 gpm for implements. I cannot say it's very fast, but that depends entirely on engine rpms. I run it just above idle and barely have time to collect the split pieces while the ram is going up. Then I must put a new piece of wood under the splitter. So IMHO speed is not really important if you are working by yourself.
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #6
Fred...shoulda mentioned earlier: Look HERE for a calculator-just plug in your numbers and you can make a decision.
Thanks for the info. I will look at it
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #8
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #9
   / 2305 or similar sized and the northern tool 3pt 13 ton log splitter #10
Splitting wood alone sucks.
I make sure I have a helper, otherwise its just not safe when splitting big pieces, because I split on a horizontal splitter, and the heavy pieces fall on your feet and legs, and then you have to pick them up again. I hate the vertical position, because my back can't handle that for very long at all. The lifting off the ground is horrible for anyones back.
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56435)
Midwestern...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
25ft Tag Trailer (A56435)
25ft Tag Trailer...
