FEL/front weight
/ FEL/front weight #1
nap61
I have a CT225 with FEL. I would like to remove the fel when hogging, bladeing, etc. I looked at the Bobcat front bracket and suitcase weights ($$$ ouch - 500.00). Has anyone bought the BC bracket/weights? If so, can you take the weights off and leave the bracket on with the fel attached? It looks like a tight fit. If not, what have you done to put on front weight when the fel is removed?
Norm
/ FEL/front weight #2
I thought about it. Although you can add as much as you need, I'm just going to buy a heavy duty box blade for balast to the rear.
/ FEL/front weight
Gumshu,
What about FRONT weight?
Norm
/ FEL/front weight #4
Gumshu,
Norm
Hi Norm. Front weights would be nice to have, but I haven't given that much thought. Sorry I don't have any useful information for you.
/ FEL/front weight
This is the reply from Bobcat:
Hello Norman,
You can keep your bracket for the suitcase weights mounted on the tractor and also hook up your front end loader. As you stated, you will need to remove the weights from the bracket prior to hooking the loader up.
Thank you for contacting Bobcat Company.
Bobcat Company
Website: Home Page - Bobcat Company
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
HOG FEEDER (A64281)
HOG FEEDER (A64281)
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A61572)
2016 New Holland...
2006 IMT 16000S3 Knuckleboom Loader Crane (A61573)
2006 IMT 16000S3...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
