Hydraulic Pump---YM2020
/ Hydraulic Pump---YM2020 #1
Eddie
North Alabama
YM2020 & Allis Chalmers 6060
The hydraulic pump on my 2020 has started to squeel at high RPMs. It's not starving because I heard that sound when I first bought it and the screen was stopped up. This is a different sound. It only does it when the pump is not loaded. When you load it by moving the loader or 3PH it is quiet.
Are these rebuildable, if so where could I get parts?
Thanks:eek:
/ Hydraulic Pump---YM2020 #2
They are not really rebuildable. Only the internal orings & seal are available but that does not sound like your problem since it only does it when NOT under load. Do you notice any lack of lifting power?
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Still has plenty of lifting power but did notice the smell of "hot" hydraulic fluid when bush hogging today. Just have a feeling it might be a bushing or bearing. (Dont have a parts breakdown for it)
Do any of you vendors have a used or new pump?
If so PM me with price.
Thanks
/ Hydraulic Pump---YM2020 #5
I would make sure the servicing lock valve is not partly closed and check the screen again.
/ Hydraulic Pump---YM2020 #6
they all have them go to hoyes page. He is around 325 if i think on new and LMTC is like 275. I found one on ebay for like 235 if you search ebay for yanmar hydraulic it should come up, its free shipping there too. Hoyes used parts are generally half of the new price so if hes 325 new expect around 175 used.
/ Hydraulic Pump---YM2020 #7
Is the noise all the time or when cold? Maybe the fluid needs to warm up? just a thought.
/ Hydraulic Pump---YM2020 #8
/ Hydraulic Pump---YM2020 #9
Does it squeel when you max out the cylinder travel and let it go into relief?
/ Hydraulic Pump---YM2020 #10
If the FEL is plumbed in series with 3ph, I would by-pass it to eliminate it as source of blockage, which sounds like what you have.
/ Hydraulic Pump---YM2020 #11
pay attention to what normde2001 wrote. I think he is on the right track.
I have a quick connect hose already made up for when I took the FEL off. I'll try that, but it seems that when it's running unloaded and makes the racket but quiets when you load it sounds like a bushing or something like that.
I will change fluid and clean screen before I replace the pump.
/ Hydraulic Pump---YM2020 #13
Put a pressure gage in the system so you will know where the pressure is and how much.
/ Hydraulic Pump---YM2020 #14
It could be a bad bushing or something in the pump but I would try to eliminate as much as possible before blindly digging into/replacing it.
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
NEW Wolverine PD-12-08D Skid Steer Post Pounder (A62679)
NEW Wolverine...
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
Suzuki RMZ 450 Dirt Bike (A62613)
Suzuki RMZ 450...
