Hydraulic Upgrade
/ Hydraulic Upgrade #1
oneparsec
I have a M/F 1010 with a factory 1014 loader and wanted to increase the ability of the loader to lift a little more than the factory 500 lbs to around 8-900 lbs
Would putting a larger pump increase lift?
/ Hydraulic Upgrade #2
Generally no.
You would need some combination of larger diameter cylinders, perhaps higher pressure and almost certainly more ballast on the back.
EDIT:
I had meant to add that even then there is no guaranty that the lift arms or some other part wouldn't fail.
It is probably dangerous to upgrade ONLY the hydraulics and finish up with the capacity to lift more than the frame of the loader can safely carry.
Stability is another issue. Lifting 800 or 900 lbs with a tractor designed and built to lift 500 lbs is one thing.
CARRYING that load is another thing and in my experience there isn't a lot of point in lifting something if I don't have a need to put it somewhere else.
Also, all four cylinders would probably need to be upsized, no point in lifting it if the curl/dump it back/forwards to maintain level.
This is moot if the frame can't (/shouldn't be asked to) take it anyway.
:END EDIT
1994 Trailmaster Aluminum T/A 407 Chemical Tanker Trailer (A64194)
1994 Trailmaster...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
New/Unused Electric Winch (A65583)
New/Unused...
3-Pt Hydraulic Tree Spade (A66285)
3-Pt Hydraulic...
