Cheap Canopy , real cheap! $8
/ Cheap Canopy , real cheap! $8 #1
MRCONCDID
North Florida
2007 L48 Kubota
I will be the first to say I am cheap, some things I just can't seem to want to pay for or at least not as much as they want for it.
Heres what I did.
I need/wanted a hard canopy.
shopped around and for a alluminum on for 325$ ouch and a tin one for 200$
fiberglass for 400$
I have some skills so I made one for 8$ insted
At the local salvage yard (heaven) I found a
4x4x1/4 road sign made of alluminum paid $6 for it
1- 10ft piece of 1 in round pipe and bent it into a squared-U
1-10ft of 1inch pipe insulation foam and some self tapping screws 2$
welded 2-2 1/4x2 1/4x3 box to my ROPS up and down
slid inside a piece of 2 in about 10in long and drilled for a bolt or pin.
welded 1/8 triangle to the 2in and the round pipe were they met for a gussett
painted and wrapped the round pipe with the insullation and screwed through the sign/insulation into the pipe, the insulation is for any sound or vibration.which I have none!
so now I have a alluminum 4x4 canopy with a steel frame and so far on a trailer I have had it up to 75mph with not problems and it is really tuff on tree limbs too.
side note my sign says "men at work" on it and it faces up the reflective coating should help with the suns heat and you could grind it off if you wanted to. I like having the "men at work" sign just incase the wife thinks Im out playing and not working...again
I have 2 orders for the cheap canopys one for a zero trun and the other for a deere. being cheap is begaining to cost me.
/ Cheap Canopy , real cheap! $8 #5
Very clever use of recycled materials. I love to see people do stuff like this. :D
here are some pics to better explain
attachment.php
attachment.php
http://www.tractorbynet.com/forums/attachment.php?attachmentid=143617&stc=1&d=1256571917
/ Cheap Canopy , real cheap! $8 #7
Very Nice. I like how clean and simple you made it. No waste or extra's used to get the job done. Congratultions on both your budget and accomplishment.
Eddie
/ Cheap Canopy , real cheap! $8 #8
A good job done .... and a job done good. Way to go.
/ Cheap Canopy , real cheap! $8 #9
Looks better than you initially described.
I'll bet it really looks great looking down on it!!!
Thanks
for all the compliments this was something I just threw together this summer.The reason for the pins/blots was I wanted to be able to take it on and off quickly, my neighbors is a factory canopy and it uses clamps on the ROPS it takes him about 10 min to get it on and then level it up, mine just drops into the outer square tubing and the blots line it up level, takes about 2minutes on or off. I wasn't sure how high to mount it so I left the inner tubing longer set in the seat and then stood up to piered over the bucket, that told me how high it needed to be not to hit my head and also getting on and off the tractor. once I knew that I drilled the holes for the pins and was done. I have always like making something out of nothing but it still has to look and work like store bought.
/ Cheap Canopy , real cheap! $8 #11
And just think....if you have the unfortunate experiance of 'flopping' over your tractor, at least people will know you are "working"!!:D:D:D
/ Cheap Canopy , real cheap! $8 #12
Looks great! cleaver use of recycled stuff. I am now thinking of doing the same !
/ Cheap Canopy , real cheap! $8 #13
hey buddy it looks great i will for sure look into doing that we priced out a canopy for my 4105 deere it is 545.00 plus tax thx :)
Summers over and the Cheap Canopy has worked great it kept the sun off my back, it was so hot steam came off of it when I poured water on it.
I have caught it on several limbs and branches with out any damage try that with cavas
As for the top having a sign on it I have thought about a coat of Cool Seal its bright white and thick like a tar it would acts as an insulator and a better refective surface.
But honestly it may be the best cheap thing I have ever built.
I have seen alot of great ideas here and I am Happy I could share this one with you all.
/ Cheap Canopy , real cheap! $8 #15
hope the sign doesnt have an H with a circle around it,:) youll have a helicopter trying to land on you
/ Cheap Canopy , real cheap! $8 #17
You should check google earth of where you work. Chances are good there will be an image of "men at work" from high above.
/ Cheap Canopy , real cheap! $8 #18
Very nice, simple but elegant. Having a canopy sure is nice on a sunny day isn't it?
/ Cheap Canopy , real cheap! $8 #19
Great job I've been looking and searching and your idea is the best I've seen.
/ Cheap Canopy , real cheap! $8 #20
I like it. That's the best idea since the golf cart roof people spoke of . Around here golf cart roofs are nearly impossible to find but those old road signs aren't . Nice idea and it's not going to crack and split from the sun. What I want to know is how you can rig one of those so I can pull it easily out of the way when I have the ROPS down. Just aint no way I'm going to leave that headache bar up all the time knocking dents in my shed and garage entries. It sure would be nice to have something up top like that though when you want it.
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A61572)
2025 Kivel Fork...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
2022 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2022 Caterpillar...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
JOHN DEERE 8360R TRACTOR (A63291)
JOHN DEERE 8360R...
