Satoh s650g Headlights
/ Satoh s650g Headlights #1
jdmainolfi
I recently bought a Satoh s650g tractor and have a stupid question, but it is bothering me. When I turn the headlights on the second setting after the guage light (i assume low beams) turns on the left light (sitting on the tractor) and the third setting (i assume high beams). Is this the way the tractor works or do i have some issue there. I bought new bulbs thinking maybe the low is burned out on one and the high on the other, but no luck. Any assistance will be much appreciated!
/ Satoh s650g Headlights #2
Where did you finf the bulbs ?
Thanks
/ Satoh s650g Headlights #3
You are correct as the function of the switch settings. Your headlamps are actualy low and high beam. Actual light bulb (element) has two elements. Specs are 25 watt/ 25watt 12 volt. It is possible that one of the filaments on each bulb may have broke or burned out. You could check these easily with a multimeter to see if theyre ok. Another possibility is to check for broken, shorted out, or melted together wires in your wiring harness that goes from your light switch all the way to the bulb sockets.
Incedently as to finding these bulbs these are similar to bulbs that were used in some snowmobiles.
My satoh bison also had similar headlamp issues.
Good luck!
/ Satoh s650g Headlights #4
I found bulbs at batteries plus.
crossed the stanley PN
/ Satoh s650g Headlights #5
If they are the same as many of the smaller Satohs, you can also find them at a motorcycle dealer. Take one with you.
/ Satoh s650g Headlights #6
Good luck!
I second what Lebby is saying. I had similar issues with left only lamp and high beams on low etc...
After some hunting around I discovered the "SH-25" bulbs stood for "scooter headlamp, 25 Watt". I got them off the shelf for about $9.00 taxes incl. for a four pack at a motorcycle shop. International and Mitsubishi dealers wanted $20.00 a bulb, three weeks plus order time???
With good bulbs installed, I discovered that the quick connects on the harness going to the hood (where it tilts and removes at the lower left frame) just needed to be swapped back to their correct positions to get high and low beams, as well as my original left right puzzle sorted out.
All is working fine now.
WWHQ
/ Satoh s650g Headlights #7
wwhQ
A buck saved here and a buck saved there..... This all adds up.
Now if we could only figure out how to save the time. Wher does it go?
LEBBY
/ Satoh s650g Headlights #8
WWHQ,
Where did you purchase those SH-25 headlamps? I was checking around, but the shops ask for a specific model and mentioning the Satoh S650G just confuses them. Also, anyone know where I can find parts/assembly drawings for the Satoh?
/ Satoh s650g Headlights #9
WWHQ,
hoosier1;
I purchased my bulbs at a Honda and Kawasaki dealer couple of years ago. Stopped in at the dealership to get some #s from him today. He wrote down three different sources for these bulbs. Had a problem with his handwriting, guess I should have been reading with it as he wrote it down. Oh Well. He did tell me they were about $3-4 apiece.
I did end up with one good #. It is Eiko A-3603 12V 25/25W Part # A3603-BP
Comes up on the 'net as being a replacement bulb for several applications including Honda Sportrax's, Kawasaki, Polaris and Yamaha. Imbelieve some of these were like ATVs. Prices on these were around $6 per 2pk carton.
Also checked out website at 1000 Bulbs. Used the Eiko # listed above. Wow! You can get a 10 Pk for $6.33. Course then there is shipping which is about $10. Still would figure out to be only #1.63 / bulb and probably never have to buy any more ever again.
Hope this helps out
LEBBY
/ Satoh s650g Headlights #10
Thanks so much Lebby. My entire reflector are missing on both sides of my Satoh S650G. I thought maybe this was built like a headlamp on a car as a whole unit. I wonder if there is a part for the reflector that can be purchased as well from the motorcycle shop? I may take some measurements and stop by one of the shops.
Hoosier1
/ Satoh s650g Headlights #11
hoosier1,
If I understand you right, you thought these were a "sealed beam" light? No there not. So right now what have you got? I'm picturing six wires (4 red and 2 black) running up to the two holes in the front of the hood assembly (bonnet) as they call it. Anything besides the holes?
Will go to the shop later today. Look at mine and look up parts#s and description.
LEBBY
/ Satoh s650g Headlights #12
hoosier1,
First off let me somewhat retract what I posted here previously. I said that these headlights were not "sealed beam" lights. At least I wouldn't class these as being true sealed beam lights. A moot point I guess. Mox Nix. Six of one half a dozen of another.
However, after consulting the official Satoh Tractor S650G parts catologue which was published by Satoh Agricultural Machine Mfg. Co., LTD. The glass lens and the cup assembly are actualy one unit however the bulb is inserted from the rear and turned to lock into place.
Catolog lists as follows:
Ref 1 Part # CA28283 -sealed beam unit Q'ty 2
Ref 2 Part # CA28284 - bulb Q'ty 2
Ref 3 Part # CA28285 - socket ***'y (R.H.) Q'ty 1
Ref 4 Part # CA28286 - socket ***'y (L.H.) Q'ty 1
Ref 5 Part # CA28287 - coil spring Q'ty 6
Ref 6 Part # A3000051 -nut Q'ty 6 - M5
Ref 3 was sold as unit - Part # CA2828Q (R.H.) -Contains Ref # 1-2-3-5-6
Ref 4 was sold as unit - Part # CA2828U (L.H.) -Contains Ref # 1-2-4-5-6
I beleive that Bill schaffer tractor probably would have these parts available.
Hope this might help some.
LEBBY
/ Satoh s650g Headlights #13
Hoosier1
Just wondering if you were able to find headlight lens' for your Satoh?
Also I do have a couple of wiring diagrams for the satoh Bison. Would just need some guidance as to how I would accomplish this for you to receive?
Have a good day!!!
LEBBY
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2018 Jeep Grand Cherokee Trackhawk 4x4 SUV (A64557)
2018 Jeep Grand...
