Shop Tricks
   / Shop Tricks #101
So you are saying I won't be able to buy new t12 ho bulbs in the future?
I just spent a few hundred bucks putting up 8ft fixtures in my garage:eek:
They are the quick start cold temp ones. They don't whine, but they do cause radio interference.
I saw the t8 fixtures when I bought the t12's. I had no idea they were planning on doing away with t12's:confused:
For cheap fluorescent bulb I buy the fleet electric brand form Home Depot. I have had them in my basement for the past six years with no problems. I also have them in all three of my garage door openers with no problems.
About the 5000k I was talking about is a light level scale not the temp of the sun. It refers to the whiteness of light. They are getting rid of the phrase warm light or cool light you used to see.
The new electronic ballast will cause interference. But they make a RF filter than you can install on the circuit and remove the static you hear. Also if your electrical system is not grounded properly it can cause noise on you electronic equipment.
Yes, you will not even be able to buy T12 lamps any more any ware curtsey of government energy standers.:(
   / Shop Tricks #102
These mini brushes from Harbor Freight are pretty good for small orifices.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Mini brushes specialized for cleaning the smallest areas, including tubing, spray guns, air caps, air passages, and fluid nozzles.
Brush sizes: 12mm, 20mm, 23mm, 25mm and 30mm; Length: 4"
Smallest is 12 MM (about 1/2 inch) I wonder what kind of a spray gun they clean with that. :confused:
Bruce
   / Shop Tricks #103
It would seem that Harbor freight got the numbers wrong in the description.
That is the set I bought, here is a pic.
   / Shop Tricks #104
Ken glad you caught that.Sounds like i could clean my chimney with the big ones lol
   / Shop Tricks #105
I'm sure everyone would like one of those TV show shops where everything is neatly hanging from a peg board. The trouble for guys in the secular world is the hook pulls out when you grab a wrench. I bet I poured six inches of concrete over a couple hundred hooks just to teach em!!
This can be ended with a glob of silicone caulk over the hook. I finally have that shop wall.
Kinda fun to actually put my tools away rather -than look for them.
   / Shop Tricks #106
bobodu, do you put the silicon glob on the end that goes in the pegboard or under the hook so it glues to the pegboard? :confused:
   / Shop Tricks #107
Hot-melt glue accomplishes the same thing.:)
   / Shop Tricks #108
>> DRILL PRESS TIPs <<
There are THREE holes around a keyed chuck for a reason.
There are also three "bit grippers" to match those three holes.
When chucking a bit, progressively tighten in ALL THREE HOLES, going from hole to hole, tightening a little more each time.
Doing thus, your bits will be held tighter and the chuck will last much longer.:cool:
When a chuck is so tight that you can't loosen it with the key, remove the bit from one of those 4-in-1 screw-drivers and use the hollow shaft for a "cheater bar".
Better yet, take some two-part plumber's epoxy stick and permanently afix the chuck-key into the shaft of the screw-driver that you already lost/broke the bit, thus making a nice chuck key with extra leverage.:)
To contain the mess when using cutting oil on the bit, put a block of wood for support, or the vise, inside a shallow card-board box on the drill-press table with the flaps standing up.
Crumple up plenty of old papers/rags inside the box to soak up the oil.
The box flaps will catch most of the sling-off and most of the oily shavings will fall into the box.;)
When drilling larger holes through steel, there is a point when the bit is almost through, when there is only a thin ring of material around the perimeter of the hole, that the bit starts violently grabbing.
Before breaking another bit, or getting knocked in the head when your project gets hurled at you by the spinning bit, STOP RIGHT THERE and quit drilling.
Put the work-piece in the vise and finish reaming that last bit of metal with the die-grinder.
Your bits will live much longer and your work will be safer.:cool:
Keep the drive-belts just loose enough that, when the bit grabs and wants to sling the work-piece across the shop, the belts slip instead.
My press has been set up as such and I haven't worn out a belt, nor spun a bearing, in over thirty years.
Also, my many years as a horse-shoer has trained my instincts to know just when a machine is fixing to "kick" and I un-consciously compensate by immediately tightening my hold on the work-piece.;)
For precision drilling, they make such a thing as a center-drill, which is a fat-shanked bit with a very skinny tip.
The fat shank prevents the bit from flexing, while the small tip centers within the punch mark and cuts a pilot hole.;)
I have one of those spring-loaded center punches that simply pushing down on it "snaps" the internal hammer and strikes the punch; it is about the handiest item I ever used for center punching.:)
   / Shop Tricks #109
My turn...
Use Valve lapping compound to get extra grip on a socket that is slipping.
Today I was removing the camshafts from a 150,000 Subaru engine, The 10mm bolts don't have a lot of torque, but over time they get tight. I had to move to a 6 point 3/8 drive socket with a long handle, and felt two of the bolts start to slip. I ran and got some valve lapping compound and coated the head of the bolt- it provided enough friction to remove and reuse both bolts.
If its starts to slip, try this trick.
Steve
   / Shop Tricks #110
My turn...
Steve
Good tip. Works with Philips head screws, too.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2018 Ford F-550 4x4 Altec AT37G Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
