Chain Saw holder/clamps ?
/ Chain Saw holder/clamps ? #1
Dave5264
Gold Member
Near North Ontario Canada
08 Montana C5264, 2011 McCormick CX100 XS
Hi Guys, anyone got a good simple design /setup for storing /carrying your Chain saw on the Tracor ? Pics would be great
/ Chain Saw holder/clamps ? #2
I use this method for my small or big saws (or both), as well as for the
gas can and face shield. My Husky Rancher has the 2-ft bar, so it sticks
out a little. If you look closely, you can see where my axe is mounted. I
do most limbing with the axe.
If you do a search, you will find a couple of scabbards that others have
made.
/ Chain Saw holder/clamps ? #5
made.
That is very nice - I've been thinking on the same sort of additions. It still irks me a bit that JD does include such accessories considering the prices they charge.
When I do add a carrier it will never hold anything Makita. Worst tool I've ever owned is a Makita DCS401 16" 39cc chain saw. It is a complete horror - runs for about 10 minutes then quits, and will not restart until it is cold again, tried everything I can think of. Adding insult to injury it has a "Happy Start" sticker next to the compression release. Sorry, rant mode off.
/ Chain Saw holder/clamps ? #6
Makita is the maker of many of my tools: 12v drill, 9.6v impact driver,
9.6v diamond saw, hypoid saw, recip saw, finish sanders. All have been
great, and never a problem.
The chainsaw pictured is the no-longer-made DCS34. I had an accident
where it got smashed while cutting a tree down. Blade was bent 90-deg
and housing broken. The case parts are too expensive, so my repairs
have been custom. Except for the vulnerability of the plastic, this has
been a great saw. I had a low end Stihl CS170, which was inferior.
I once rented the big Makita DCS54 chainsaw...it was awesome. I would
have bought one but my Husky was tons less $.
/ Chain Saw holder/clamps ? #7
/ Chain Saw holder/clamps ? #8
I know. I own other Makita tools and have been well pleased with them all. But I tell you this Makita chain saw is so aggrevating I lose objectivity whenever I see one. I once called Makita, they volunteered to repair it. Probably the coil, they said, which is $150 (plus labor / shipping). It's not the coil, spark is fine, anyhow no coil on earth that I can lift is worth $150. Bought a low-end Poulan for $90 for light work and potential saw-ruining work (stumps, etc.), it works beautifully, along with the old Homelites I own. Someday I'll finally give up and the Makita will become a target down at the range.
Sorry guys, hijack is over. NICE tractor!
/ Chain Saw holder/clamps ? #9
I glued up some plywood for a scabbard. Handy addition and keeps the saw off the ground. Always worried it would get run over, and now don't have to chase around to where I last set it down.
/ Chain Saw holder/clamps ? #10
/ Chain Saw holder/clamps ? #11
I just take 3 pieces of 1/4" plywood that are slightly larger than the bar/blade. Trace the bar outline on the middle one and cut it out with a jigsaw. Then glue/screw the three together. This gaves you a blade guard that can be bolted wherever and you just drop the saw into it. Gravity keeps it in. When the chain chews it up too much you make another. I have two, one on each side, bolted to my FEL brackets. One hangs straight down, the other at an angle
Great ideas Guys, thanks for posting...ill learn to "search" next time.
i like the simplicity of the ply wood approach, love the ALum & Cutting Board version.
thanks again
/ Chain Saw holder/clamps ? #13
I had some solid vinyl deck boards left over from redoing my deck -- I dadoed a slot to fit the blade in one and made a scabbard like the plywood one above. Bolted to one to my carryall and made one for the tractor not yet mounted. Woodgrain finish even:p
