Mowing 755 mowing kinda funny
/ 755 mowing kinda funny #1
dieselram
Gold Member
Meadville, PA
2007 John Deere 3120 TLBM
I just got a real nice used 755 for mowing. My question is why would the center blade cut way (1/2") or so lower than the 2 outside blades? It is the 60" mid mower. Is that a sign of a bent blade? What else could be wrong?
/ 755 mowing kinda funny #2
Make sure the blade is installed properly. There is a lip that the blade has to go past when mounting on the hub. If it were tightened down without being past that it would be about a half inch low.
/ 755 mowing kinda funny #3
Could be a bent blade or a bad spindle. I would guess blade.
/ 755 mowing kinda funny #4
Get out your measuring stick and check the blades in several spots. I'm sure by looking carefully you'll find the reason..
BTW congratulations on the 755 purchase, lots of good things said about the 55 series, and the 755 in particular. :)
/ 755 mowing kinda funny #5
If the above suggestions don't correct the problem, then check to make sure the deck level is adjusted correctly front to back. The front of the deck should be slightly lower than the back, but no more than a 1/4" lower.
/ 755 mowing kinda funny #6
Measure the end of each blade from a flat surface like a concrete floor. Rotate each blade and measure again. If there is a difference it could be a bent blade or bent spindle. It's very hard to bend a spindle but I have bent a couple. You can take your blades off and stack them. If one is bent you will see it in the stack.
Got the time to tear the deck off and guess what- the blade was on upside down! Mows great now! Thanks for the help, I never would have thought of the blade though. Here are a couple of pics.
/ 755 mowing kinda funny #8
WOW:eek: That thing looks better that new!
/ 755 mowing kinda funny #11
Amazing find! How many hours are on it?
960, a guy who restores Corvettes repainted the body panels. That old JD green paint they used faded a ton. It was done right-no rattlecan special! Added a hardener to the paint to make it more durable and shine longer.
Here is a couple more pics.
/ 755 mowing kinda funny #14
Very nicely done. Was the seat replaced? Some of the early models came with a yellow seat, but I know you can still buy OEM yellow or black ones. The yellow would be cooler during summer use. I attached a couple pics of mine with 608 hours.
/ 755 mowing kinda funny #15
Very nice looking tractors. I have an 88 model with about 3400 hrs on it. Mine doesn't look to bad for its age but not as good as those two do.
/ 755 mowing kinda funny #16
How do guys keep the foot deck so nice, floor mats?:D
/ 755 mowing kinda funny #17
When I see older ones the foot deck is always terribly worn, so I used to expect mine to get that way eventually. But I have not seen any signs of wear and I do nothing to protect it. So I do not know why the difference.
/ 755 mowing kinda funny #18
Whatever you're doing (or not doing) keep it up.;)
The seat was a yellow replacement, not original. I should flip my rear wheels like yours!
Willmar Wrangler 4500 Loader (A66285)
Willmar Wrangler...
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
