Mowing 755 mowing kinda funny
   / 755 mowing kinda funny #1
dieselram
Meadville, PA
2007 John Deere 3120 TLBM
I just got a real nice used 755 for mowing. My question is why would the center blade cut way (1/2") or so lower than the 2 outside blades? It is the 60" mid mower. Is that a sign of a bent blade? What else could be wrong?
   / 755 mowing kinda funny #2
Make sure the blade is installed properly. There is a lip that the blade has to go past when mounting on the hub. If it were tightened down without being past that it would be about a half inch low.
   / 755 mowing kinda funny #3
Could be a bent blade or a bad spindle. I would guess blade.
   / 755 mowing kinda funny #4
Get out your measuring stick and check the blades in several spots. I'm sure by looking carefully you'll find the reason..
BTW congratulations on the 755 purchase, lots of good things said about the 55 series, and the 755 in particular. :)
   / 755 mowing kinda funny #5
If the above suggestions don't correct the problem, then check to make sure the deck level is adjusted correctly front to back. The front of the deck should be slightly lower than the back, but no more than a 1/4" lower.
   / 755 mowing kinda funny #6
Measure the end of each blade from a flat surface like a concrete floor. Rotate each blade and measure again. If there is a difference it could be a bent blade or bent spindle. It's very hard to bend a spindle but I have bent a couple. You can take your blades off and stack them. If one is bent you will see it in the stack.
Got the time to tear the deck off and guess what- the blade was on upside down! Mows great now! Thanks for the help, I never would have thought of the blade though. Here are a couple of pics.
   / 755 mowing kinda funny #8
WOW:eek: That thing looks better that new!
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
Kawasaki NR (A50324)
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
