Grease Fitting
/ Grease Fitting #1
DIRTCUTTER
New Mexico
CK30 HST
Ck30 hst w/BH I need to replace a couple of grease fittings on my backhoe KB2375
What size are these fittings
/ Grease Fitting #3
I have a grease fitting on my backhoe that won't thread in straight and I must have stipped it trying to get it secured. Is there a self tapping 1/8 " P.T. replacement zerk available, Bob?
Thanks,
rimshot
/ Grease Fitting #4
Have you tried a 1/8" pt tap? I have not seen a self tapping zirk fittings. I would try chasing the tread carefully with a tap to restore the thread. If not, you may need to drill it out and go to the next size zirk.
/ Grease Fitting #5
Sounds like a good job for one of these up and coming rainy days, Bob. I should be able to drive the cylinder pin out and simply run a 1/8" P.T. tap completely through the damaged empty zerk threads. After I run the tap, I'll keep the pin and bushed opening free of thread cuttings before I reassemble.
Gulp, why did'nt I think of that?(smile)
Thanks again,
rimshot
/ Grease Fitting #6
Thanks,
rimshot
I've had 3 I've had to replace on my 2385 and none would thread without first cleaning up the threads. I tried several different zerks and they all needed work. Apparently, the factory uses something other than a good clean tap.
The nipple's on the factory zerks seem to be really fragile too.
/ Grease Fitting #8
Another post claims -They are a 10mm X 1mm taper thread grease fitting. When I looked at my 20HST, they indeed were European pipe thread.
/ Grease Fitting #9
The original poster was referring to his KB2375 Backhoe when he asked the question regarding replacing zerks.
I can confirm that the grease zerks in my kb2465 Backhoe use 1/8th Pipe thread. The CK20 zerks are metric I believe.
rimshot
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
LOADER MOUNT HAY SPEAR (A63291)
LOADER MOUNT HAY...
Kubota M4700 (A60462)
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
