Grease Fitting
/ Grease Fitting #1
DIRTCUTTER
New Mexico
CK30 HST
Ck30 hst w/BH I need to replace a couple of grease fittings on my backhoe KB2375
What size are these fittings
/ Grease Fitting #3
I have a grease fitting on my backhoe that won't thread in straight and I must have stipped it trying to get it secured. Is there a self tapping 1/8 " P.T. replacement zerk available, Bob?
Thanks,
rimshot
/ Grease Fitting #4
Have you tried a 1/8" pt tap? I have not seen a self tapping zirk fittings. I would try chasing the tread carefully with a tap to restore the thread. If not, you may need to drill it out and go to the next size zirk.
/ Grease Fitting #5
Sounds like a good job for one of these up and coming rainy days, Bob. I should be able to drive the cylinder pin out and simply run a 1/8" P.T. tap completely through the damaged empty zerk threads. After I run the tap, I'll keep the pin and bushed opening free of thread cuttings before I reassemble.
Gulp, why did'nt I think of that?(smile)
Thanks again,
rimshot
/ Grease Fitting #6
Thanks,
rimshot
I've had 3 I've had to replace on my 2385 and none would thread without first cleaning up the threads. I tried several different zerks and they all needed work. Apparently, the factory uses something other than a good clean tap.
The nipple's on the factory zerks seem to be really fragile too.
/ Grease Fitting #8
Another post claims -They are a 10mm X 1mm taper thread grease fitting. When I looked at my 20HST, they indeed were European pipe thread.
/ Grease Fitting #9
The original poster was referring to his KB2375 Backhoe when he asked the question regarding replacing zerks.
I can confirm that the grease zerks in my kb2465 Backhoe use 1/8th Pipe thread. The CK20 zerks are metric I believe.
rimshot
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2016 Chevrolet Silverado 1500 Pickup Truck (A61573)
2016 Chevrolet...
2011 John Deere 9770 (A64119)
2011 John Deere...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A63689)
Midwestern...
